Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 03:15 PM   #1
breaker box
we have lived in this house for 2 yrs and about 6months ago the breaker that runs three outlets in my kitchen just quit, we replace with a new breaker and as soon as you turn on power it throws again any suggestions?
lajen867 is offline   Reply With Quote
Old 03-23-2010, 03:23 PM   #2
Just call me Andrew
Rewards Points: 1,020
Take a look in the outlet boxes. Look for a loose wire or some sort of short (black wire touching something it shouldn't be?)
Could be a loose "backstab" connection (wire simply pushed into a hole in the back of the outlet). If so, you might want to replace these outlets with a "backwire" style, where you stick the wire under a clamp and tighten the screw.
Andrew
secutanudu is offline   Reply With Quote
Old 03-23-2010, 05:59 PM   #3
so with the old breaker, when you reset it, it would immediately trip out again? and thats why you installed a new breaker that is doing the same thing? am i right?
naehring2000 is offline   Reply With Quote
Old 03-23-2010, 09:39 PM   #4
Electrical Contractor
kbsparky's Avatar
Replacing a breaker that trips does not fix the problem(s) in your circuit that caused a short circuit.
Call an electrician to troubleshoot your wiring before you burn your house down by repeatedly applying power to a bad circuit.
-KB
Old 03-23-2010, 10:02 PM   #5
Angry
Just last week, I went on a service call for an intermittent trip in a kitchen with several outlets and a light fixture. turns out someone ripped out an outlet in a handy box with the brick nails (old work) left inside. (probably did it with a crowbar) while installing a new kitchen. Every time the (loose) box shook, the nails made contact with the Hot wire and the box.!
spark plug is offline   Reply With Quote
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
