Old 04-02-2008, 06:33 PM   #1
Lehigh Valley PA
Breaker box
Is there any standard as to how a breaker box needs to be mounted in a residential application?
Reason I ask is I would like to mount one sideways surface mounted on the wall.
It is a 200A panel with 40 spaces.
Also what is the standard mounting height?
Thanks.
Nhrafan is offline   Reply With Quote
Old 04-02-2008, 06:39 PM   #2
Electrician
Breaker box
Here is one reason...
chris75 is offline   Reply With Quote
Old 04-02-2008, 07:45 PM   #3
joed's Avatar
Breaker box
That's a big difference between NEC and CEC. It is common to mount a breaker panel on its side in Canada. We can also have more than 42 breakers in one panel.
Old 04-02-2008, 07:46 PM   #4
Lehigh Valley PA
Breaker box
Originally Posted by chris75 View Post
Attachment 2969
What is this supposed to mean?
I looked up the section and all I can find is this:
"240.33 – The first sentence of this section has been rewritten to permit enclosures for overcurrent devices to be mounted in other than a vertical position when it is not practical to do so."
Old 04-02-2008, 08:19 PM   #5
Licensed electrician
Breaker box
On must be Up. This precludes the mounting of panels on their side.
The middle of the handle of the highest breaker can be no higher than 2 meters or 6'7".
Old 04-02-2008, 09:20 PM   #6
Union Electrician
goose134's Avatar
Breaker box
Actually it doesn't preclude mounting them on their side, but it does eliminate half of the panel.
goose134 is offline   Reply With Quote
Old 04-02-2008, 09:27 PM   #7
nap
You talking to me?
nap's Avatar
Breaker box
as soon as '08 code is adopted, we can too.
Old 04-02-2008, 09:35 PM   #8
Lehigh Valley PA
Breaker box
Another ? I have is this...
Is there a limit to how many double pole breakers that can be installed in a 40 circuit box?
I ask because I have radiant heat and each room is a separate zone so I have seven 20A double pole breakers already plus the one for the oven, the range top, water pump, the welder, and the portable heater outlet in the garage.
So I am wondering how many are allowed in a box and if there is a limit.
Old 04-02-2008, 09:36 PM   #9
nap
You talking to me?
nap's Avatar
Breaker box
I would have to say
20
Old 04-02-2008, 09:38 PM   #10
Breaker box
That would be 20
220/221 is offline   Reply With Quote
Old 04-02-2008, 09:40 PM   #11
Lehigh Valley PA
Breaker box
Thanks guys!
I appreciate it.
Old 04-02-2008, 10:36 PM   #12
Breaker box
Unless the panel is listed for use with tandems the answer could be zero.
What is the brand and part number of your panel?
Old 04-03-2008, 08:17 AM   #13
When is fishing season?
CowboyAndy's Avatar
Breaker box
Why would the answer be zero? If the panel was listed for 40 circuits, then 20 dp breakers could be installed.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-03-2008, 08:41 AM   #14
Breaker box
Andy,
I disagree, the panel label will show if and where the tandems can be used. The 40 circuit panels I have seen and installed do not allow tandems. The mounting rails will not allow the use of CTL (circuit tandem limiting) breakers. Use of non-CTL breakers are listed for replacement use only.
A panel like a QO200M3040 takes 30 full size breakers but can use 10 tandems to makeup the 40 circuits. The devil is in the details.
On a side note why use a breaker than is more than double the cost over a single?
Old 04-03-2008, 08:49 AM   #15
Electrical Contractor
Breaker box
The question was "how many double poll breakers could fit?"
Tandems are not double poll breakers.
hpp58 is offline   Reply With Quote
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
