-   -   Breaker box (http://www.diychatroom.com/f18/breaker-box-19422/)
Nhrafan 04-02-2008 05:33 PM
Breaker box
Is there any standard as to how a breaker box needs to be mounted in a residential application?
Reason I ask is I would like to mount one sideways surface mounted on the wall.
It is a 200A panel with 40 spaces.
Also what is the standard mounting height?
Thanks.
chris75 04-02-2008 05:39 PM
1 Attachment(s)
Attachment 2969
Here is one reason...
joed 04-02-2008 06:45 PM
That's a big difference between NEC and CEC. It is common to mount a breaker panel on its side in Canada. We can also have more than 42 breakers in one panel.
Nhrafan 04-02-2008 06:46 PM
Originally Posted by chris75 (Post 113303)
Attachment 2969
What is this supposed to mean?
I looked up the section and all I can find is this:
"240.33 The first sentence of this section has been rewritten to permit enclosures for overcurrent devices to be mounted in other than a vertical position when it is not practical to do so."
Jim Port 04-02-2008 07:19 PM
On must be Up. This precludes the mounting of panels on their side.
The middle of the handle of the highest breaker can be no higher than 2 meters or 6'7".
goose134 04-02-2008 08:20 PM
Actually it doesn't preclude mounting them on their side, but it does eliminate half of the panel.
nap 04-02-2008 08:27 PM
as soon as '08 code is adopted, we can too.
Nhrafan 04-02-2008 08:35 PM
Another ? I have is this...
Is there a limit to how many double pole breakers that can be installed in a 40 circuit box?
I ask because I have radiant heat and each room is a separate zone so I have seven 20A double pole breakers already plus the one for the oven, the range top, water pump, the welder, and the portable heater outlet in the garage.
So I am wondering how many are allowed in a box and if there is a limit.
nap 04-02-2008 08:36 PM
I would have to say
20
220/221 04-02-2008 08:38 PM
That would be 20 :thumbup:
Nhrafan 04-02-2008 08:40 PM
Thanks guys!
I appreciate it.
Jim Port 04-02-2008 09:36 PM
Unless the panel is listed for use with tandems the answer could be zero.
What is the brand and part number of your panel?
CowboyAndy 04-03-2008 07:17 AM
Why would the answer be zero? If the panel was listed for 40 circuits, then 20 dp breakers could be installed.
Jim Port 04-03-2008 07:41 AM
Andy,
I disagree, the panel label will show if and where the tandems can be used. The 40 circuit panels I have seen and installed do not allow tandems. The mounting rails will not allow the use of CTL (circuit tandem limiting) breakers. Use of non-CTL breakers are listed for replacement use only.
A panel like a QO200M3040 takes 30 full size breakers but can use 10 tandems to makeup the 40 circuits. The devil is in the details.
On a side note why use a breaker than is more than double the cost over a single?
hpp58 04-03-2008 07:49 AM
The question was "how many double poll breakers could fit?"
Tandems are not double poll breakers.
