Breaker Or ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 04:52 PM   #1
Breaker or ???
I have a detached garage that "suddenly" went dead. I have a sub-panel with 220 and a 50A circuit for my spa. NO breakers were tripped. Went to main panel..again NO breakers tripped. I have reset all breaker switches (turn of/on several times). I believe I isolated the breaker @ main panel that feeds garage..I changed it...it still doesn't work. The breaker I replaced was a double pole/1 bar switch. Any Ideas??
kentsw is offline   Reply With Quote
Old 12-04-2010, 05:33 PM   #2
Ground Fault Circuit Interrupt device? I assume that it is possible your garage is on such a protected circuit.
oberkc is offline   Reply With Quote
Old 12-04-2010, 05:52 PM   #3
Electrical Contractor
kbsparky's Avatar
Bad underground wire. Happens a lot when one uses direct burial cable.
If your lines are installed in conduit, then maybe your breaker at the main panel is bad .... but I'd wager on the bad underground first ....
-KB
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
