Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 06:43 AM   #1
Breaker?
I am putting in a sub-panel in the basement. My main panel is a square d it looks like i need to use a "hom250" (homeline series) is there any cross reference as to another breaker i can use? I see that my local HD doesnt have square d on their website.
So is there another brand that will work in its place?
baum is offline   Reply With Quote
Old 09-01-2009, 06:49 AM   #2
HD does not list a lot of items that are carried in the store on their web-site
What is your main breaker rating ?
What size sub are you running?
Old 09-01-2009, 06:52 AM   #3
Main panel (square d) is going to get a 50a, and the sub is a 125a rated eaton cuttler hammer. I ran it with 6-3. I am only running 3 circuits in the sub (20a for bathroom, 15a living room, 15a arc fault bedroom)
Old 09-01-2009, 06:55 AM   #4
The local HD's near me all carry the Homeline brand
If it's a bit of a drive call them 1st
Old 09-01-2009, 07:02 AM   #5
So my main panel does not have a main breaker in it. I already have my sub wired (no breakers in it) and basement wired (going to schedule rough-in electrical this week). When i pass and get towards then end of the project how should i go about hooking that 50a up to the main? I know how to hook it up but with the live power is what i question. Ground... netrual... red-black to breaker. insert breaker in the off position and snap it in or what?
Old 09-01-2009, 07:05 AM   #6
There isn't any shut off ahead of the main panel?
I have added breakers to a live panel, but prefer to shut them off
Yes, I wire up the ground & neutral 1st
Then attach hots & snap it in - with the breaker off
Old 09-01-2009, 07:07 AM   #7
Thanks for the replies!
PS i just looked at your house reno NICE work. Are you just a DIY'er or in the trades?
Old 09-01-2009, 07:18 AM   #8
Thanks, i'm just a DIY'r
But I've been doing DIY stuff since I was a kid
This house the major upgrades/building are "done"
"Just" need to do the finish work mostly
Old 09-01-2009, 09:22 AM   #9
Licensed electrician
Rewards Points: 1,610
You would need to use either the BR or CH classic breaker in your panel. CH classic has a brown enclosure.
Homelines and QO are not listed for use in CH panels.
Old 09-01-2009, 09:27 AM   #10
I am trying to figure out the main panel. i know the sub needs the ch. I was just wondering if there is something else besides the square d homeline that will work in the main panel. I just didnt see any homeline on the home depot website
Old 09-01-2009, 10:04 AM   #11
WaldenL's Avatar
Rewards Points: 268
Why would you ever add them hot? Sure, I guess it's safe enough if you're careful, but "safe enough" just doesn't seem right in a box w/150 or 200 amps. I can't see having to add a breaker so urgently that you can't wait until you can turn off the main.
I'd view adding a hot breaker like changing out a switch while the line is hot. Can it be done? Sure. Would a DIYer do it, nope. Would a pro? Not likely. Would someone that thinks they're a pro but hasn't been bitten enough time to actually be a pro do it? Probably. At least that's how the pros I know describe it to me.
WaldenL is offline   Reply With Quote
Old 09-01-2009, 10:07 AM   #12
My question is how do i have the power company come and pull the socket and get the final electrical inspection at the same time?
we currently live in the house so we cant go without power.
Old 09-01-2009, 10:13 AM   #13
WaldenL's Avatar
Rewards Points: 268
When I say "change it hot" and I _think_ what Scuba Dave means is w/out turning off the main breaker. I don't mean having to pull the meter. If you're prepared you should be able to kill the power by flipping the main breaker, add and wire the new breaker and turn the power back on in < 5 minutes.
Old 09-01-2009, 10:16 AM   #14
Will there be an accessible shut-off on the meter one where i can just flip a switch or will the electric comapny need to do it? like do i need to break there little wire tag they put on?
Old 09-01-2009, 10:22 AM   #15
WaldenL's Avatar
Rewards Points: 268
OK, just re-read the thread. There is no main breaker? I can't believe that. Can you post a screen shot of the main box? There's got to be some sort of disconnect either in the box, or ideally, by the meter. But it should not be inside the meter. We're taking about something that would be accessible to the Common Joe.
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
