Breaker For 2 Bedrooms? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 05:12 PM   #16
the Musigician
DangerMouse's Avatar
I hate to ask the obvious, but why are you all using space heaters? Is there no main furnace?
DM
Old 08-18-2011, 05:40 PM   #17
Electrical Contractor
kbsparky's Avatar
Who would want to run heaters in THIS weather??
-KB
Old 08-18-2011, 06:07 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
The simple fact is that your overloading the circuit breaker. Even if you had a 20A breaker supplying both bedrooms....your really pushing your luck on running both of them at the same time.
If your asking questions in order to get amo to 'encourage' the land lord to upgrade the elctrical....I don't think that is going to happen.
A 1000w heater is a lot of heat....Add in the 100W bulb (have you considered a CFL?), your laptop and the TV.....even if the breaker is a 20A.....your pulling too much.
Unless the room is not insulated and dos not have any other heat.....I would suggest warm fuzzy slipers and warm PJ's....
ddawg16 is online now   Reply With Quote
Old 08-19-2011, 12:46 PM   #19
good solutions!
I like the fuzzy PJs idea... Thanks everyone for their expertise!
GMill is offline   Reply With Quote
Old 08-19-2011, 01:19 PM   #20
seansy59's Avatar
Rewards Points: 258
I have a oil filled space heater. The low setting only uses 600 watts, and warms the room very well.
Low- 600w
Med- 900w
High- 1500w
They are very energy efficient, and on low, you should be able to fit 2 comfortably on 1 circuit.
A 15 amp circuit can handle 1875w
A 20 amp circuit can handle 2400w
seansy59 is offline   Reply With Quote
Old 08-20-2011, 06:55 AM   #21
Rewards Points: 3,130
GMill: A long shot perhaps, but rental properties often have more stringent requirements. There are some areas where residential rental properties must be registered, inspected, and cannot legally be rented if they aren't up to current codes, regardless of how old they are. You might check - I was once able to get out of a lease (in MD) because the landlord had never gotten a required lead-based paint inspection. Of course, depending on what you discover, you might end up homeless LOL.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
GFCI breaker trips randomly BimmerRacer Electrical 40 09-21-2009 02:11 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
