Brand New Gfi Wont Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 10:40 AM   #1
Brand new gfi wont reset
Just replaced my kitchen outlets with brand new GFI outlets. I purchased a 3 pack of them. 2 of the three wont reset. These particular outlets have a little green light so I know all three are getting power, but only one would reset and is functioning. Any ideas on whats going on here? Is it possible that 2 of the three are just bad?
bfuccillo is offline   Reply With Quote
Old 05-24-2011, 12:02 PM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Double check your wiring. My guess is they are working fine and you have some kind of issue were they are tripping as you reset them.
Big N8 is offline   Reply With Quote
Old 05-24-2011, 01:37 PM   #3
I ask the impossible!
Rewards Points: 712
Ayup. GFI's will only reset when they're powered and wired correctly and are shipped in the tripped state.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-24-2011, 03:06 PM   #4
Rewards Points: 512
Only one GFCI receptacle is needed; other standard receptacles downstream can be connected to the load side of the GFCI offering protection to those downstream receptacles.
The GFCI needs to have the source (cable from panel) connected to the LINE side of the GFCI. The LOAD side is for connecting other receptacles downstream.
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Water heater reset is tripping. rjniles Plumbing 7 11-24-2010 08:15 AM
Boiler needs to be reset Chris12047 HVAC 8 11-12-2008 02:28 PM
Oil burner won't kick on, have to push reset edski HVAC 4 11-06-2007 02:04 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 10:13 AM
