Brand New Building...where Are My Grounds? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2008, 08:01 PM   #16
BTW, Ranalli, those are NOT self grounding receptacles.
Could the bottom screw have the self grounding hardware on it or is it on both screws? Rarely ever see them here.
If the bottom screw looks just like the top one...just a screw and a plastic retainer, it's not self grounded and needs a pigtail.
220/221 is offline   Reply With Quote
Old 09-18-2008, 08:05 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I can tell just from looking at it. Those are $.49 Cooper receptacles.
They are not self grounding.
Old 09-18-2008, 08:13 PM   #18
Then...go get em Ranalli
Old 09-18-2008, 08:21 PM   #19
Originally Posted by Speedy Petey View Post
BE VARY CAREFUL.
Just because you bought this place DOES NOT automatically mean you can do electrical work there. Many multi-family dwellings are in areas that prohibit untrained, unqualified and unlicensed folks to do work.
There is WAY more at stake than your small portion of the structure.
I certainly wasn't planning on it...trust me
ranalli is offline   Reply With Quote
Old 09-18-2008, 08:23 PM   #20
Originally Posted by Matsukaze View Post
Boy, Speedy Petey sure lives up to his name. He posted three replies while I was composing this one.
It looks like your condo is wired with type AC cable. The small aluminum wire that's folded back under the connector isn't exactly a ground wire, it's a bonding wire. The metallic sheath of the cable is the grounding conductor. I can't tell from your photo, but if the receptacles are self-grounding like this they don't need a grounding wire connected to the green screw, as long as they're installed in a properly installed, grounded metal box. It looks as if that box is recessed too far--it ought to be flush with the drywall.
I see....yes I definitely have that setup with the bonding wire..it's wrapped to the flexible conduit behind the receptacle seems like.
Old 09-18-2008, 08:25 PM   #21
BTW, Ranalli, those are NOT self grounding receptacles. I just noticed the picture link.
They absolutely DO require a ground jumper to the box.
Really? Thanks for letting me know!!
But all I would need to do is put self-grounding receptacles in then...correct? Easy fix?
Old 09-18-2008, 08:27 PM   #22
I guess I'm going to have to....these guys are such maroons!!! This will be one of many things that wasn't quite right.
Old 09-18-2008, 08:39 PM   #23
Yup and yup.
Old 09-18-2008, 09:03 PM   #24
Yeah, looks like the label on the receptacle was Cooper 270W which is just a standard grade:
http://64.239.63.88/catalog/pdf/G%2016.pdf
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
