Branch Circuits - 12-2 In PVC Conduit? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 10:15 AM   #1
Branch Circuits - 12-2 in PVC Conduit?
I've been doing some research and finding a lot of conflicting information.
This is my situation:
My main panel is in my garage. I want to run 3 20-amp branch circuits to my basement. The garage has drywall and living area above, so I need to run the wires outside the drywall. My plan was to pull 3, 12-2 NM through PVC conduit from the panel to the basement. I would have to go from the panel to the ceiling, across the ceiling, and down the opposite wall. Two 90 bends and about 48'. The conduit will be for protection only.
Here is the question:
Can I run the NM wires through a single conduit? If so, what size?
Should I run the NM wires through 3 separate conduit runs of 3/4"?
Thanks in advance
zutroy is offline   Reply With Quote
Old 07-22-2011, 11:26 AM   #2
Rewards Points: 3,130
I believe that except for short distances for protection, it is a code violation to run Romex inside conduit. I would use THHN conductors.
Old 07-22-2011, 11:53 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks in advance
Running NM through conduit is code compliant. 3/4 is not going to be large enough. 1 1/4 PVC schedule 40 is the size needed. Good luck!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-22-2011, 11:53 AM   #4
Master Electrician
Rewards Points: 3,874
It is NOT a code violation.
brric is offline   Reply With Quote
Old 07-22-2011, 12:37 PM   #5
Electures,
Do you mean the 3/4" will not be large enough for all three wires, or just one?
i.e. Can I run all three 12-2 wires through one 1 1/4 PVC, or should I run each 12-2 through its own 1 1/4 PVC?
Old 07-22-2011, 02:12 PM   #6
Licensed Pro
One 1.25" conduit with three runs of 12/2.
Old 07-22-2011, 05:33 PM   #7
electures's Avatar
Electures,
One conduit for all three cables. Is the conduit running from box to box?
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Two circuits in single conduit? Codi Electrical 4 11-21-2010 09:44 PM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 09:06 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Entire Rewire or New Branch Circuits? Typ0 Electrical 44 01-29-2009 10:54 AM
