Branch Circuit ?s - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2008, 04:16 PM   #1
Branch circuit ?s
Can you use a box to split a circuit, like in the picture? I know I can use a 14/3 to continue the circuit past a switched light but the box would be easier and not require a trip to HD.
Ben
Bcoleman6 is offline   Reply With Quote
Old 01-26-2008, 04:23 PM   #2
Sure. Use a covered junction box with cable clamps. Electrical Code, I believe requires that the junction box be accessible and not enclosed within a wall.
Is this new construction? From your drawing it appears that you have the 2nd circuit going to a closet. You could just use just branch off from Ceiling Box No. 3
Randell Tarin is offline   Reply With Quote
Old 01-26-2008, 04:38 PM   #3
How is light number 2 going to be switched. If we follow your drawing, you would need a bit of 14-3 between light number 2 and 3.
Master Electrician
jwhite is offline   Reply With Quote
Old 01-26-2008, 04:51 PM   #4
Here is a simplified wiring diagram of BOX 3. I don't show the ground wires for illustration clairity. all the ground wires would be twisted together here.
Old 01-26-2008, 05:24 PM   #5
Light 2 will be run off the switch for 3. So I will run the switch for light 1 from the box for 3 and run 14/3 from 2 to 3 so I can use a switch loop for 2 and 3. Looks like I have to run to HD for some 14/3.
Old 01-26-2008, 06:28 PM   #6
One more piece to the puzzle. 1 is new, 2 and 3 are currently attached to another branch circuit. 3 bedrooms, 2 bathrooms, and all the lights in the drawing are on a double pool 20Amp breaker. So I am removing some things and putting the on thier own circuit. 2 and three are at the end of the run but I can only trace the wire leaving 3 up into the wall on the first floor. I know the right way to do it would be to find where it is conectted and remove it. If I can't is there any thing else I can do? Like cut it, cap it and leave it in a box? If not any tips on how to trace it?
Old 01-26-2008, 06:49 PM   #7
waiting for spring
arichard21's Avatar
Rewards Points: 150
I am assuming you meant double POLL 20 AMP breaker. The bathrooms have to be on a seperate circuit ONLY servicing the bathrooms. You CAN put both on the same. This would be a good time to do it.
arichard21 is offline   Reply With Quote
Old 01-27-2008, 11:27 AM   #8
Yep shoudl have said poll. One off the bathrooms has been remodeled and once we get our new panel in on Friday it will be placed on a circuit for the lights and another for the outlets. The second bathroom currently has no outlets; I am going to continue the light circuit from the number 3 light from he drawing below. Then when we update the bathroom I will install a 20A GFCI circuit for he outlets.
Thanks for the info everyone.
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
When to bring up to code? Bcoleman6 Electrical 15 01-24-2008 12:45 PM
Is it possible to add a 4 way switch to this configuration? irich Electrical 55 11-25-2007 10:15 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Removing a branch circuit jcostanz Electrical 2 04-19-2005 11:31 PM
