Brake Light - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2008, 07:43 AM   #1
Brake Light
Could someone please tell me how to install a brake light on my motorbike? It use to be a fully working bike with lights and everything but was then stripped down. I can find the brake light wires under the seat but i don't want to take the bike apart until i get instruction on how to install the light. Can someone please help?
Thanks.
sd04 is offline   Reply With Quote
Old 07-06-2008, 09:17 AM   #2
You will have 3 wires brake,taillight and ground. To save time hook the ground up and turn on your lights. Hook the other wires to your light one at a time. The light that is the dimmest is your tail light the brightest will be the brake.Hook it to the wire that does not have power on it. When you mash the brake it should work.
BillyD is offline   Reply With Quote
Old 07-06-2008, 07:14 PM   #3
Do i need to buy a specific kind of light designed for brakes or can i use something cheaper? As i said, it hasn't got any lights at all at the moment (except for a dolphin torch i mounted as a headlight) because it was used as a farm bike for 20 odd years and was very badly treated. When it was given to us it didn't work so we took it all apart and got it working but there were no lights.
Is it as simple as hooking the brighter light wire (brake wire) to the light? What did you mean by "hook it to the wire that does not have power on it?
Thanks for your reply
Old 07-06-2008, 07:25 PM   #4
When you have the lights on the tail light wire will have power the brake will not until you mash the brake. Any cheap light will work. Is it 12V or 6V. To tell the difference the battery will have 6 caps for 12V and 3 caps for 6V.
Old 07-06-2008, 10:56 PM   #5
We took the battery out because it didn't work any more but we will buy one. The headlight is just a torch (doesn't look great but works perfect) and isn't connected to a battery. If i am only going to have the brake light attatched to it, so i will probably get a very cheap battery. Does it matter what type of battery i get.
I just remembered that i will have to connect the battery somehow to keep it charged. Seeing as it used to have a battery and lights i am assuming that it has connections to keep it charged. Do you know how to do this?
Old 07-06-2008, 11:53 PM   #6
liscenced electrician
Rewards Points: 538
is it 12 volts or 6 volts? Either get a test light, or a meter and test each wire to ground
jimmy21 is offline   Reply With Quote
Old 07-07-2008, 12:22 AM   #7
homework's Avatar
What make and model is bike ?
homework is offline   Reply With Quote
Old 07-07-2008, 12:36 AM   #8
Its a very old Yamaha 100 ag bike. Im not really sure about all the specs but i do know that.
Old 07-12-2008, 02:34 AM   #9
homework's Avatar
I am not 100% sure on one that old but most yamaha's
black= ground
yellow= brake light
blue=taillight
brown=left turn
green=right turn
since lights were removed check to make sure there is still brake light switches, one at rear pedal and one on front hand lever, and that they are still hooked up.
Old 07-13-2008, 04:15 AM   #10
What do those switches look like and how should i check if they are still working?
Old 07-13-2008, 09:21 AM   #11
Here's specs on an old fashioned parking/brake light. The brake filament uses 1.8A.
#1034 MINIATURE BULB BAY15D BASE - 12.8/14.0 Volt 1.80/0.59 Amp
I never understood why they didn't spec both filaments at normal alternator output voltage (14.4v +/- 1v), but that's another story.
Old 07-13-2008, 06:08 PM   #12
homework's Avatar
the one on the lever is mounted in or underneath the perch.
it should have two wires coming out of it.
the one on the pedal is mounted just above the pedal pivot it has two wires also.
both will be open when no brake is applied and closed when brake is applied.
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
