Old 05-09-2012, 09:05 PM   #1
Brain Dead Help Me Out Here
Guys,
My old house project has gotten me to the point of being so tired I can't think straight, with very little time to analyze the situation.
Here's the deal:
I disconnected a switch/gfci box in the kitchen in order to put in a bigger box as the old one was way too small. I didn't diagram the connections, and now it's time to put it back. Seems simple, but I can't seem to determine the connections. Five 2-wire cables enter box, with one from the panel. Below is the image I drew, with the prospective connections. Can anyone help me find any problems? I am just guessing (without putting a lot of thought into it, about the loads.
The bolded lines indicate tails.
Old 05-09-2012, 09:14 PM   #2
I=E/R
a7ecorsair's Avatar
Originally Posted by sirsparksalot View Post
Guys,
Here's the deal:
You have the black wires tied to the load terminal but not the whites for the same cables.
a7ecorsair is offline   Reply With Quote
Old 05-09-2012, 09:19 PM   #3
Oh god, I think I see it. The 3rd cable (bottom) is on the Load neutral, and I need it nutted with the other whites, and tailed to the load neutral, correct?
Old 05-09-2012, 09:49 PM   #4
I=E/R
a7ecorsair's Avatar
Wrong, if the hot is on the load the neutral has to be on the load. You have a white wire nutted to the incoming neutral that should be nutted to the wire leaving the load neutral.
Old 05-09-2012, 09:51 PM   #5
The hot isn't on the Load, it's on the Line. ??
Old 05-09-2012, 09:53 PM   #6
All protected loads, whose hot wires are connected to the GFCI load terminal group, must have their neutrals also connected to the GFCI load terminal.
All (unprotected) loads, whose hot wires are connected to the GFCI line terminal group, must have their neutrals also connected to the GFCI line terminal group.
(Power cable, both hot and neutral, goes to the line terminal group.)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-09-2012, 09:56 PM   #7
I=E/R
a7ecorsair's Avatar
Then your drawing is wrong.
Old 05-09-2012, 09:58 PM   #8
So, I am going to have to trace these loads? I know the light isn't to be protected, so that's cleared. I'm thinking that only two more receptacles are to be protected. (I'm not at the property right now, so I'm only recalling).
Old 05-09-2012, 10:00 PM   #9
How do you see the hot going to the load? Stay with me here lol
Old 05-09-2012, 10:28 PM   #10
I=E/R
a7ecorsair's Avatar
Follow from the red wire nut to the receptacle and it says load. The load side is GFCI Hot and Neutral. This feeds downstream GFCI protected devices.
Old 05-09-2012, 11:07 PM   #11
Master Electrician
your pulling the neutral off the line and pulling the hots off the gfci protected side of the plug. you need to wire nut the hots and whites of each cable respectively to the same side of the gfci (line or load) or else the gfci won't function properly
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-10-2012, 01:36 AM   #12
Can I get an Amen on this?
Old 05-10-2012, 06:03 AM   #13
That setup will protect 3 outgoing cables if that's what you are wanting to do.
zappa is offline   Reply With Quote
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
Dead Breaker? and Nusiance Tripping... jasonblu Electrical 9 11-06-2009 07:13 PM
Outlet is dead but ears are hot!? Whassup? Hubandwif Electrical 33 03-23-2009 09:01 PM
A new definition to being High-wired: Shark Off Topic 1 03-27-2008 06:50 PM
