Braided Wire Or Solid For 24 Volt - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 08:49 PM   #1
braided wire or solid for 24 volt
My sprinkler system calls for 18 guage wire to run the 24 volt solenoid valves. They say to use "direct burial" wire. Before I go to the hardware store and hum and haw......should I be looking for braided copper or solid copper wire?
I''m a little worried that nobody will know at the store.
the carpenter is offline   Reply With Quote
Old 09-04-2009, 08:57 PM   #2
Rewards Points: 1,538
Doesn't matter whether you use braided (stranded) wire or solid wire.
Except if a section of wire is subject to flexing (not a problem with buried wires) braided is better.
Old 09-04-2009, 09:44 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
Get sprinkler wire. It's special. It usually comes in four or six circuits (5 or 7 conductors) and has color coded conductors for easy identification and a direct-burial-rated jacket. You can also get single-conductor sprinkler wire. It's very heady duty for abrasion resistance. Using non-sprinkler direct burial cable will be unnecessarily expensive because the only other common type of direct burial cable is UF, which is rated for line voltage and thus more expensive.
mpoulton is offline   Reply With Quote
Old 09-05-2009, 09:25 PM   #4
Don't do cheap, get the sprinkler wire!!
Ranger31 is offline   Reply With Quote
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 09:59 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
