Bracket Will Not Fit In Light Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2014, 06:36 PM   #1
bobgodd's Avatar
Rewards Points: 101
Bracket will not fit in light box
Picked up a couple of those LED motion security lights from C*stco, and the included bracket will not fit a standard size light box. Are there oversize light box options out there, or am I going to have to cut these screws with my grinder? The screws protrude too far once the light is placed on top and the nuts will not fasten down all the way, so the light isn't sealed tightly to the top rim of the light box.
The light will be placed outside, under the eaves. As you can see from the pictures, the screws either need to be able to be backed off a bit but they physically cannot go inside the box any further; or they need to be trimmed.
How would you all approach this? Thanks!
Bracket will not fit in light box-20140101_162558-1-.jpg   Bracket will not fit in light box-20140101_162641.jpg
bobgodd is offline   Reply With Quote
Old 01-01-2014, 07:11 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Find the correct length and cut the screws. Or you can purposely orientate the box so that the mounting holes on the box line up with the cover and the fixture will sit straight. Then there would be no need for the bracket.
The Following User Says Thank You to k_buz For This Useful Post:
plummen (01-01-2014)
Old 01-01-2014, 07:12 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
cut the screws
Tom Struble is offline   Reply With Quote
Old 01-01-2014, 07:55 PM   #4
joed's Avatar
Rewards Points: 12,852
Originally Posted by Tom Struble View Post
cut the screws
It is that simple. Cut the screws.
Old 01-01-2014, 07:59 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Cut just the heads off. They look like the screw shafts will fit inside the box.
Funny, I never had this problem with a RAB fixture.
Old 01-01-2014, 08:38 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I love a fixture company that makes a bracket so the screws land on the box edge... simply brilliant!
personally, I would support the fixture with other methods if it's a large fixture.
Old 01-01-2014, 09:03 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,346
Cut the screws !
Or buy some shorter screws !
dmxtothemax is offline   Reply With Quote
Old 01-01-2014, 09:38 PM   #8
bobgodd's Avatar
Rewards Points: 101
That's not even the worst part... Because part of the bracket is raised, the body of the light does not sit tight against the light box. If I hadn't already ground off part of bracket, I'd return it.
Old 01-01-2014, 10:48 PM   #9
E2 Electrician
Why not just cut the heads off the screws, thread them into the box, and re drill the fixture if needed... I would avoid using the fixture bar, this is why electricians get paid, we are problem solvers.
Old 01-01-2014, 10:49 PM   #10
joed's Avatar
Return it anyway.
Old 01-01-2014, 10:50 PM   #11
E2 Electrician
Originally Posted by joed View Post
Return it anyway.
WHY? Just install the fixture.... You think electricians get that option? lol...
Old 01-01-2014, 11:01 PM   #12
thanks for that one..
Old 01-01-2014, 11:05 PM   #13
E2 Electrician
And DIY sites exists for what reason? Oh yeah, because people are so intelligent to start with....
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
