Old 06-26-2008, 01:48 PM   #1
Ski
Unhappy
Bracket to Ceiling mount a Wall mount floodlight
I have a wall mount heat/motion sensor utility flood light I was planning to install in place of an existing loght and when looking at the existing flood light I just noticed it was a ceiling mounted box to which the light is fastened. The new light is a wall-mounted style. Is there a bracket available to allow me to install the wall mount light using the ceiling mounted electrical box? The other exterior flood lights which have ceiling mounts (like the one I am trying to replace) are not the style I wanted, and the bright halogen light I want to use seems to only come in a wall mount style. Any ideas? Can I make a bracket myself easily?
Ski is offline   Reply With Quote
Old 06-27-2008, 12:18 PM   #2
J. V.'s Avatar
The reason you are having this issue is the new light is probably not rated for outdoor use. They do make a universal plate that will work with most any box. Usually ceiling boxes are octagon shaped or the mud ring will be round.
You may be able to take the existing box down and start from scratch. Go to a lighting store or your local HD or Lowes and you can find this plate in the lighting/fan section. I bought one last week.
Look at the options for boxes that will accommodate your fixture. Bring fixture and box if possible. You will get it resolved with no problem.
Tags
ceiling mount, mounting bracket, wall mount
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 07:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 09:04 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
