Old 08-13-2012, 07:28 PM   #1
br20 vs. br30 floodlight incandescent bulbs.
Hi,
I have a floodlight fixture in our shower stall. Inside are the maximum bulb ratings:
BR 20 size: 50 watt
BR 30 size: 75 watt
OK, BR 20 bulbs are smaller (less wide) than the same wattage as BR30 bulbs.
I always thought that since BR20 bulbs are smaller and therefore are farther away from the lamp housing sides than the large BR30 bulbs, then it would be OK to use a same wattage BR20 bulb in a BR30 fixture. But apparently that is not necessesarily correct?
Darto is offline   Reply With Quote
Old 08-13-2012, 08:04 PM   #2
Licensed Electrician
k_buz's Avatar
I don't believe it. You will need to look a shower rated trim to figure out what lamp (bulb) to install.
A can inside a shower stall will be required to be enclosed...no bare bulb.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 08-13-2012, 08:34 PM   #3
E2 Electrician
stickboy1375's Avatar
If it's required to even be a wet located trim...just because its located in a shower does not mandate a shower trim.
Old 08-13-2012, 08:36 PM   #4
E2 Electrician
Originally Posted by Darto View Post
Hi,
BR 20 size: 50 watt
BR 30 size: 75 watt
its all about heat dissipation, if the can is not rated for that lamp with that particular trim, then that is your answer...
Old 08-13-2012, 08:37 PM   #5
k_buz's Avatar
Holy .... didn't even notice that. If this is true, you need to remove that fixture.
Old 08-13-2012, 08:40 PM   #6
E2 Electrician
LOL, neither did I, but it could still easily be legal.
Old 08-13-2012, 08:47 PM   #7
OK then it is not a floodlight fixture. I'm not an electrician and do not know the associated nomenclature.
It is, however, a fixture specifically designed for shower stalls, and it takes either BR20 or BR30 bulbs.
I'll have to buy BR30, because the 65 watt BR20 bulbs that we already have a large stock of already (for living room fixtures) is over the specified 50 watts per the engraved panel inside the shower fixture.
75 watt BR30 are allowed in this shower fixture.
Old 08-13-2012, 08:50 PM   #8
E2 Electrician
75 watt BR30 are allowed.
Just make sure what you are reading is good for the trim that is being installed, they are a matched set.
incandescent fixtures banned? kainos Electrical 15 06-01-2011 06:12 PM
using 60w incandescent bulbs in fan rated for 15w CFL denemante Electrical 13 03-21-2011 12:33 PM
Replacing incandescent bulbs with CFL bulbs NightOwlNYC Electrical 5 08-19-2010 12:45 AM
CFL vs incandescent question adpanko Electrical 13 08-30-2009 11:41 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
