Boxes Required - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 05:25 PM   #1
Rewards Points: 150
Boxes required
I often see no electrical box installed in a wall where there is a light fixture like in a bathroom. The NM cable pops out of a hole in the wall and then into the light fixture. The fixture usually has a metal plate attached to the wall and then the cover with the lamps attached to it goes on next. I believe Article 300.15 requires a box for this install....am I right?
I do know there is an exception if the liminaire is listed for use as a raceway. But how common is that? I've put in some round cut-in boxes to remedy this problem, but the box would show after the fixture was installed.
You guys who do this for a living run into this same scenario? What do you do?
Steelhead is offline   Reply With Quote
Old 01-25-2009, 05:40 PM   #2
joed's Avatar
Rewards Points: 11,598
The fixture used must be rated to contain the wires. A flourescent fixture can have a cable clamp installed into it and then the fixture is the junction box.
Old 01-25-2009, 05:51 PM   #3
Rewards Points: 150
Do the fixtures normally say what they are rated for? Most of the fixtures in question are incandescent ones. 3-5 bulbs
Old 01-25-2009, 06:02 PM   #4
If the wiring was completely contained in the fixture (like a fluorescent strip) I would have no problem installing it sans box.
I have no idea what the listing issues would be. I never actually look at the small print, I just use some common sense.
220/221 is offline   Reply With Quote
Old 01-25-2009, 06:18 PM   #5
Rewards Points: 150
Thanks, I think I can figure out which fixtures will need boxes and which don't.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Boxes recessed too deep rondo Electrical 10 12-01-2012 07:46 PM
Mounting 3 gangable switch boxes mcvane Electrical 11 01-16-2009 09:43 PM
Installing 20 amp circuits in metal boxes, is 14 ga OK for ground pigtails? thegonagle Electrical 17 11-14-2008 08:34 AM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
