Box Size - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 08:45 PM   #1
Box Size
What is the minimum size box that can be used for 2- 12-2 romex and 1 14-2 romex and an outlet, entering an outlet?
thetford is offline   Reply With Quote
Old 01-21-2011, 08:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
19.75 cu/in minimum box volume.
WHY would you have two 12/2 and one 14/2 in a single box with one device?
Old 01-21-2011, 09:21 PM   #3
Light to switch
I am using a 14-2 going to the light from the switch.
Old 01-21-2011, 09:22 PM   #4
joed's Avatar
Rewards Points: 12,848
If it is a 20 amp circuit then ALL the cable must be #12. If you use the 14/2 you must be on a 15 amp circuit.
Old 01-21-2011, 09:25 PM   #5
Sorry, I am doing this for my husband and I haven't taken the time to figure this site out !! Will check with the forum first, next time!
Old 01-21-2011, 09:39 PM   #6
Very common DIY mistake, and it IS a mistake that should be corrected.
Old 01-21-2011, 09:39 PM   #7
Rewards Points: 6,652
Petey, looks like they are gathering info over time. This is the third post regarding the same subject in the lines of Electrical. From looking at a previous, it is in regards to a Kitchen. Not something that I would want to see in the end.
Old 01-21-2011, 09:40 PM   #8
Ouch. I hadn't noticed.
Old 01-21-2011, 10:07 PM   #9
I had to go back and look at the OP posts, and it does not look pretty. From the looks of it, what ever they are doing should be on DIY Renovation Realities.
Old 01-21-2011, 10:27 PM   #10
What are you saying? Exactly?
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
