Box Mounting B4 Cement Pour - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 01:28 AM   #1
Rewards Points: 49
box mounting b4 cement pour
What is the best way to mount the 4"x4" metal boxes inside the forms before the cement is poured into the forms?? the boxes are already attached to the PVC...thanks
jambud is offline   Reply With Quote
Old 08-13-2009, 12:45 PM   #2
Rewards Points: 160
Make a small hole in the form, right in the center where the box will be. Take a length of ty wire and pull the box (from the inside) against the inside of the form. Twist the ty wire over a piece of wood or a small piece of conduit. Make it good and tight. This will hold it from the outside.
Note: Remove the screws from the box. So it lays flat. Put a dab of grease in the screw holes, or put tape over them. Tape the box with masking tape to keep the concrete from entering. Some will enter through the front where it meets the form. This is okay. It will be very thin with no rock. Make sure you put some tape over the connectors, so none can enter the conduit. When the form comes down, you may need to chip it out if the form does not clear it for you first.
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
cement wet after pour zantar Building & Construction 5 06-24-2009 05:04 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
