Box Hell - Is This Correct? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 09:53 PM   #1
box hell - is this correct?
http://imageshack.us/a/img845/3389/wwcv.jpg
Aye. I'll explain. Top right is 12/2 power in. Middle top is 12/2 to porch light. Top left is 12/3 for a 3 way switch going to the dining room light. Bottom right is 12/2 going to an exterior outlet. This isn't being fed off the dining room SABC btw, just for clarification. 32cu in box.
This blew my mind so I tried to work through it, and I can see it's going to be a royal PITA to shove into the box. Before I shove it all in, I just want to make sure this is correct. I'm not at all sure if this is correct.
Tonglebeak is offline   Reply With Quote
Old 10-06-2013, 11:15 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,490
What is not correct ???
Elaborate please !
Did it work ?
dmxtothemax is offline   Reply With Quote
Old 10-06-2013, 11:25 PM   #3
Rewards Points: 366
looks a little tight , why 12 & not14 gauge? btw i've seen far worse.
circuitman is online now   Reply With Quote
Old 10-06-2013, 11:32 PM   #4
20amp circuit
Old 10-07-2013, 04:17 AM   #5
Licensed electrician
Rewards Points: 1,750
You can use the green grounding wire nuts and leave one long tail to ground the switches.
Philly Master (10-07-2013)
Old 10-07-2013, 04:45 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I would undo it, make up your neutrals and push them out of the way.
Make up your grounds and leave a pig tail(s) push them in out of the way, while staggering the wire nuts.
Make up your hot with pigtails and push out of the way, leaving only the wires going to your switches hanging out.
After connecting your switches, pre-bend the wires so they will fall in place.
Make sure your wires are not too long.
If your going to be doing a lot of this, you may want to purchase some of these for your grounds to eliminate those big red nuts.
wirenut1110 is offline   Reply With Quote
Old 10-07-2013, 04:51 AM   #7
Rewards Points: 510
Also, it looks like your grounding and feed pigtails are too short.
You may want to make them longer to allow more flexibility.
Old 10-07-2013, 07:19 AM   #8
Rewards Points: 756
It you use those, you will need to buy the right crimp tool. I'm tired of seeing those just mashed with side cutters.
Mark
busman is offline   Reply With Quote
The Following 2 Users Say Thank You to busman For This Useful Post:
itsnotrequired (10-07-2013), Jim Port (10-07-2013)
Correct to HOT/NEU Reverse in camper. jpaytoncfd Electrical 6 07-20-2012 12:16 AM
Need Advice on how to Correct Low Water Pressure Joe Tilghman Plumbing 51 04-13-2012 12:11 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
IS it correct? allawi Building & Construction 3 11-09-2009 06:49 AM
Correct oil level in Bristol compressor Aptguy HVAC 5 08-26-2009 09:56 AM
