Which Box For Flush-mount (in-wall) Outdoor Electrical Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 12:21 PM   #1
Which box for flush-mount (in-wall) outdoor electrical outlet?
I'm adding an electrical outlet by running cable from an inside outlet in the same cavity. I will have a GFCI outlet inside, and run a regular grounded outlet off of it to the outside (as I've seen suggested here).
My question is about receptacle boxes: I know I can use a bell box, mounted to the surface, and then a waterproof cover. But which box would I use if I want to cut a hole in the siding and mount in the wall? Can I use the regular indoor old work boxes, or is there a special outdoor version? I haven't seen anything at the home improvement stores that mounts inside the wall and is specifically for outdoor use.
Thanks for any advice.
plambert is offline   Reply With Quote
Old 10-27-2011, 02:21 PM   #2
Licensed electrician
Rewards Points: 1,892
Since the box would be inside the wall you could use a regular old work box.
You could also use one of these.
http://www.aifittings.com/catalog/we...roof-products/
plambert (10-27-2011)
Old 10-27-2011, 03:05 PM   #3
Perfect, thank you.
Want to mount a sconce on the wall where there is a stud pdp76 Electrical 24 04-01-2011 05:07 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
flush mount dryer outlet bryan1282 Electrical 8 10-01-2010 06:17 PM
wall mount toilet jjrbus Plumbing 8 11-12-2009 01:07 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
