Box Fill And Wire Nuts - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 09:27 AM   #1
Rewards Points: 172
Box fill and wire nuts
Hello:
I have a question amout box fill with wire nuts and pigtails. I have a 2 gang box with 12/2 coming in and two 12/3 wires going out. The box is for 2 switches. I was having problems getting 5 wires under one wire nut so I pigtailed them to another wire nut. So what it looks like in the box now:
-3 white wires under 1 wire nut
-3 green under 1 wire nut pigtailed (4 in total under the first wire nut) to another wire nut with 2 grounds running to each switch (so 3 in that wire nut)
- 3 blacks under 1 wire nut pigtailed (4 in total under the first wire nut) to another wire nut with 2 more wires running to eache switch
So there are 5 wire nuts in the box. This box is in a shallow wall and is only 25 cu. inch. Is this acceptable for box fill?
Here is a rough sketch of what it looks like:
zephed666 is offline   Reply With Quote
Old 05-02-2011, 09:35 AM   #2
Licensed electrician
Rewards Points: 1,226
Your box is too small. For box fill you have 13 #12's x 2.25 cubic inches = 29.25.
Under the NEC pigtails and wire nuts do not count towards fill. Under the CEC wire nuts count towards fill.
Old 05-02-2011, 09:54 AM   #3
Rewards Points: 172
How did you get to 13 #12's? Any suggestions to fix this, again it is a shallow wall?
Old 05-02-2011, 10:02 AM   #4
Licensed Pro
one 12/2 = 2
two 12/3 = 6
ground =1
two switches = 4
total = 13, assuming you have no internal clamps.
Old 05-02-2011, 10:05 AM   #5
Rewards Points: 172
Originally Posted by HouseHelper View Post
one 12/2 = 2
two 12/3 = 6
ground =1
two switches = 4
Again, how can I rememdy this in the shallow wall? Do they make a shallow 2 -gang box that is as wide as a 3 gang?
Old 05-02-2011, 10:16 AM   #6
Licensed Pro
How shallow is the wall? What is behind it? Is there a wall covering?
You may be able to use a 4" square box (metal) with a deep mud ring to gain enough room, or a three gang box with one space in the cover blanked.
Old 05-02-2011, 11:37 AM   #7
Rewards Points: 172
I was using an old work box since I didn't want to tear out a portion of the wall. The new work box I just picked up will fit and it is 32 cu. in. and states 14/12 wires on it. So I should be ok with the box fill now.
Is how I connected it in the diagram inpost 1 a problem? Or is it acceptable to use multiple pigtail and wire nuts since they son't fit under 1 nut?
Old 05-02-2011, 01:51 PM   #8
Licensed Pro
The multiple wirenuts is not a problem, but you could also use larger wirenuts (blue) or Wago-style pushin connectors that accept eight wires.
The Following User Says Thank You to HouseHelper For This Useful Post:
zephed666 (05-02-2011)
Repairing broken wire secutanudu Electrical 15 04-20-2010 12:44 PM
Sub-Panel Wire Size and Conduit Questions Tmb9862 Electrical 3 12-03-2009 12:48 AM
Wire fill bobo60 Electrical 9 04-25-2009 08:42 PM
Running Wire Bocolo Electrical 11 01-24-2009 12:56 PM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 09:46 AM
