Box Fill Question, Is Fan Canopy Included? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 02:49 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Box fill question, is fan canopy included?
I have participated in several threads lately that discussed box fill capacity. The question rises about using a 6 cu in pancake box to mount a fan. 6 cu in is only enough by code for a single 14-2 cable. When in fact when mounting a ceiling fan the connections end up in the canopy rather than in the box.
Is it code compliant to include the capacity of the fan for box fill? I have never seen 1 that has the cu in listed on it. The same question can be asked about mounting a wall sconce with a canopy to a pancake box.
Coastal South Carolina
Old 11-01-2012, 04:49 PM   #2
Code05's Avatar
Rewards Points: 1,104
314.16(A) Box Volume Calculations. The volume of a wiring
enclosure (box) shall be the total volume of the assembled
sections and, where used, the space provided by plaster
rings, domed covers, extension rings, and so forth, that are
marked with their volume or are made from boxes the dimensions
of which are listed in Table 314.16(A).
314.16(B)(1)Exception: An equipment grounding conductor or conductors
or not over four fixture wires smaller than 14 AWG, or
both, shall be permitted to be omitted from the calculations
where they enter a box from a domed luminaire or similar
canopy and terminate within that box.
Code05 is offline   Reply With Quote
Old 11-01-2012, 11:13 PM   #3
Just write the volume inside the canopy with a sharpie.
Hundred is offline   Reply With Quote
Eljer toilet circa 1996 question noone Plumbing 0 08-02-2011 10:27 AM
How to properly fill stress cuts in concrete before tiling? vseven Tiling, ceramics, marble 20 06-07-2011 09:53 PM
LP / NG - Unusual Question... Peter B. Appliances 8 04-09-2011 09:59 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
