Box Fill Dilema - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 06:21 PM   #1
I ask the impossible!
Rewards Points: 704
Box fill dilema
What's my best option for a ceiling box for a smoke detector? I'm roughing-in wiring, right now I have 1 box that has 3 14/3 cables coming into it, and it looks like the only way I can run cable to my last box is to run a 4th 14/3 cable into the same box. The box I have right now is 25 cu. in. and I believe the calculations would say I need 32 in.
An extender would give be another what, 3 or 4 cu. in? not enough.
I could go to a 2-gang box that is 34 cu in. Would the smoke detector cover this, or how would I close this box and run a wire through the cover?
Or do I put up a second box nearby and run 3 cables into each box (24 cu in.)
WillK is offline   Reply With Quote
Old 12-05-2010, 06:26 PM   #2
Master Electrician
Rewards Points: 3,918
You don't have another smoke detector box with only one or two cables in it?
brric is offline   Reply With Quote
Old 12-05-2010, 06:45 PM   #3
Licensed electrician
Rewards Points: 1,766
Put in a deep 4" square box and add a single gang plaster ring.
Old 12-05-2010, 07:05 PM   #4
Rewards Points: 704
This particular box is the closest to everything on the first floor, on the first floor I'm putting in boxes for a first floor bedroom, a smoke detector outside the first floor bedroom and one near the kitchen. The second floor is gutted so I can run wires easy. The first floor is not gutted, and the options for connecting the first floor boxes are shortest by at least 10 feet per run by connecting at this one box on the second floor.
The first floor bedroom is also adjacent to the circuit box, so I'll be connecting power from that box. The power feed for the circuit can be 14/2, can it not?
Old 12-05-2010, 07:11 PM   #5
Master Electrician
14-2 fed from a 15 amp breaker is correct. IMO you are asking for years and years of false trips if you install a smoke detector near the kitchen.
Old 12-05-2010, 08:03 PM   #6
Rewards Points: 704
For that one I have photoelectric. I have read things both that a smoke detector for a kitchen is asking for false trips and that it's a prudent choice. I'm putting it in knowing both sides, and I'm planning that if it becomes too much of a nuisance I'll just take it out and cap the wires in the box and cover it with a blank. I already have the first floor covered otherwise, so no code issues with taking it out if I have to.
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-20-2009 11:13 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
cinder bloc shed - fill or no fill ? amakarevic Building & Construction 3 04-16-2008 09:07 PM
