Box Fill Calculation - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 04:38 PM   #1
I live in Ontario and I'm cleaning up the wiring in a room that was partially finished when we bought the house. I noticed the boxes where pretty full so I checked my friends code book and from my understanding the boxes are to small. There is one with a branch run which has 3 14/2 in a 12.5 ci box where as from my calculations I need 20 ci. 6 conductors, 1 clamp, 1 ground, and 2 for the device x 2 for the size of the conductor which equals 20 ci . So my question is, is my understanding of how to calculate box fill in ontario correct and was this acceptable in the old code. Should I be worried about the rest of the work the previous owner did?
sketchy is offline   Reply With Quote
Old 03-17-2011, 08:45 AM   #2
Nothing?
Old 03-17-2011, 10:19 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I think Canada & the US use the same method for box fill, and 20 cubics is what I come up with too. Acceptable in the old code? Dunno. Which old code? The NEC started back in 1897. Worried about what the pervious owner did? You can answer that better than we can...but you've already found one 'oopsy'...would make me look further.
Kyle
Old 03-17-2011, 10:49 AM   #4
Ive looked at all of my switches and receptacles and they all seem undersized. I assume some are from the builder so that is why I question if I am calculating properly or if it was different 7 years ago.
Old 03-17-2011, 10:58 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
I doubt if it was different 7 years ago.
Kyle
Old 03-17-2011, 11:28 AM   #6
Rewards Points: 256
My rule of thumb is I elevate it to high priority if I see any sort of browning of the insulation on the wires.
Sounds funny, but it's really fairly common to see wires with obvious signs of overheating.
Disclaimer: I am not saying it's ok to leave it as is if there are no signs of overheating.
michaelcherr is offline   Reply With Quote
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-21-2009 12:13 AM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
Box Fill Calculation SS396 Electrical 19 09-29-2008 10:19 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
Load Calculation ? RM575 HVAC 9 07-04-2007 01:37 PM
