Box Fill - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2005, 11:27 PM   #1
Box fill
The blue 2-gang romex box reads on the inside that it is for 16 #14 wires so many 12's etc. Are they considering a 14-2 with ground one wire or three wires? What about a 14-3 with ground. Thanks in advance. HS
K2eoj is offline   Reply With Quote
Old 09-12-2005, 09:41 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
All grounds count as 1 wire, all others count as single wires. 3#14/2 w g is counted as 7 wires, plus the device will count as 2 each. So a 2 gang box that allows 16, #14 wires and has 2 switches in it will only allow 14 wires.
Hope that answer your question
Old 09-13-2005, 12:07 AM   #3
Got the first part, but I'm coming up with 12 in your second example. Did i miss something? Also, If a guy likes to pigtail to the outlets do those wires get counted? Makes more sense now, i thought 16 pcs of romex in a box seemed like alot. Thanks again. HS
Old 09-13-2005, 04:41 PM   #4
jbfan's Avatar
Rewards Points: 252
Math was never my strong suite!! You are right, I forgot a switch! The pigtails do not count.
Old 09-14-2005, 12:11 AM   #5
Thank you, that helps. HS
Routing an oil fill? sandyman720 HVAC 1 03-07-2007 11:25 AM
