Box For Exterior Wall Sconce - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 07:15 PM   #1
Rewards Points: 41
box for exterior wall sconce
I am re-siding my house and would like to install an electrical box for a wall sconce exterior light.
The siding will be (in order) 7/16 OSB, housewrap, and 5/16 hardiboard.
What steps can I take to prevent water intrusion? What type of electrical box is most popular for _exterior_ wall sconces? what should be the depth of the box with respect to the finished surface?
If you know a link or links to explanations, that would be great!
Tom
tom31415926 is offline   Reply With Quote
Old 06-30-2012, 09:21 PM   #2
Rewards Points: 13,274
http://www.sturdibuild.com/gallery.shtml
One I like better is one I've been buying at Lowes, it is the siding block and electrical box all in one, you can even add a differant trim ring that way bigger if you have a bigger light.
Old 06-30-2012, 11:23 PM   #3
Rewards Points: 41
joecaption,
Thanks. I didn't know these existed.
I have to look for more information about them:
How thick are they?
Where do the mounting screws of the light fixture go?
How is it flashed with housewrap?
is there an electrical box behind it?
I can start by going to Lowe's and asking questions.
Tom
Old 06-30-2012, 11:28 PM   #4
There not going to have a clue, Just ask where the vinyl siding is, your lucky if they even know that much. Once you see it, it's simple to figure out how to install it.
It will look like a 2 X 4 handi outlet box built in. It can be used for an out box or a light box. If it's a light you just mount it horizontal so the screw holes line up with the light fixture.
tom31415926 (07-01-2012)
Installing Sconce between electrical panels danielrg Electrical 9 04-25-2012 05:44 PM
Trouble replacing a wall sconce elmonty Electrical 4 07-17-2011 07:05 PM
wall sconce pbdesign Electrical 9 12-28-2010 02:30 AM
Exterior sconce box and feed cable requirements Ptron Electrical 10 08-11-2010 01:54 PM
Sconce placed in studs? RedBear Electrical 11 02-04-2010 09:21 PM
