Bought Wrong Type Of Wire. Can I Still Use It? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 06:05 AM   #1
Bought wrong type of wire. Can I still use it?
I am wiring in an outlet, and not paying much attention at the hardware store accidentally bought outdoor 220 wire (with the 4 wires instead of 3). Is it legal to still use this and just cap the extra wire, or do I have to go buy more?
Thanks!
busterbluth123 is offline   Reply With Quote
Old 06-26-2012, 06:15 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
As long as the wire size is rated for the circuit size it would be fine. But I am assuming that you bought xx-3 UF. That can be really expensive, a PITA to work with, and worth the trip back to get the right stuff.
Old 06-26-2012, 06:22 AM   #3
Thanks for the response. Yeah, I think that is what I bought. And it was actually cheaper, which is why I grabbed it. I was kinda in a hurry, and thought the cheaper one must be what I needed. It has been a bit of a pain, but thankfully all I'm doing is running from one side of a door to the other, so it's not too bad.
What type Low Voltage wire for T-Stat? Skelleyman Electrical 3 05-10-2012 02:41 PM
What type of wire should I be using? Zellarman Electrical 27 12-04-2011 05:44 PM
Correct type of wire for a 100 amp, 160 ft run SRedinbo Electrical 8 05-01-2011 06:18 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
