Bottom Half Of Outlet Has No Power? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 07:47 PM   #1
Rewards Points: 337
bottom half of outlet has no power?
So we retextured the walls and painted and removed all outlets and switches. I marked the wires but I am having an issue with one outlet. It's not a switched outlet. There is (2) whites and (2) black and the ground wire. The top half has power and I confirmed power is at the outlet to the left of this one on the same wall. The black and white on the bottom daisy chain out and and supply power to the right side of wall but no power there??
I used the same outlet and when I removed the wires the first time I had to jam a small screw driver into the release tab to get the wire out. Perhaps I broke a connection? Any suggestions?
titan7 is offline   Reply With Quote
Old 01-08-2011, 07:52 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
new outlet?
Tom Struble is offline   Reply With Quote
Old 01-08-2011, 08:05 PM   #3
Rewards Points: 337
thats what I think I will do, but since it's dark I will do it tomorrow. On a side note, is it strange for a three way switch to not have a gound wire? I have switch upstairs and one down stairs that control the same hall light. There is only (2) blacks and a red wire. the black wires go to the top hole and middle hole, the red went to the bottom. Still can't get power here either.
Old 01-08-2011, 08:39 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
backstabbs are notorious for failure.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-08-2011, 08:44 PM   #5
DIY staff
Rewards Points: 7,174
You may have use an outlet that has the tab snapped off between the power screws---is this a used outlet?
Old 01-08-2011, 10:05 PM   #6
joed's Avatar
Rewards Points: 13,286
The only way to have power to the top and not the bottom is to break the tab on one side. There is a tab between the screws on both sides. If one of them is broke off then one half will not have power.
Replace the receptacle with a new one that has the tabs. Do not use the push in connections. Use the screw connections.
Old 01-08-2011, 10:26 PM   #7
Rewards Points: 1,532
It is not unheard of for the tab (there's one on the neutral or silver side also) to fracture partially. If that happens the usual thing to do is discard that receptacle unit and buy another. But for those who don't like to waste, you can cut two pigtails, attach one to each screw, and wire nut on the wire that used to be connected to one of the screws.
No, using one backstab hole will not work either (to power both receptacles) if the tab got fractured or removed.
Temporary Power outlet on meter pedistal vtboy51 Electrical 2 12-02-2010 06:33 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Power outlet OneLittleBoy Electrical 19 03-28-2009 05:28 PM
kitchen outlet no power apt238 Electrical 27 08-25-2006 07:37 AM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 01:08 PM
