Both Black And Red Wire Hot At Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 12:24 PM   #1
Both black and red wire hot at switch
This is new wiring. I have 2 switches controlling 2 lights and an outlet at the end of one of the runs that should always be hot. The power source goes to the switches first and then on to the lights. I have 12-2 as the source. 12-2 running to the individual light. 12-3 between the switch and light and then 12-2 between this light and outlet.
The first light works fine. The 2nd switch has black from the source and red from the light. At the light the red connects to the black of the light, the white connects to the white of the light and the white of the 12-2 running to the outlet, and the black of the 12-3 connected to the black of the 12-2 of the outlet.
How is it possible that at the switch both the black and red are hot even when disconnected from the switch?
Doug60m is offline   Reply With Quote
Old 12-03-2011, 12:33 PM   #2
How are you measuring that and with what test equipment?
Billy_Bob is offline   Reply With Quote
Old 12-03-2011, 04:37 PM   #3
Rewards Points: 6,652
You need to put a wiring diagram up showing how the circuit is wired, so that everyone can get a better understanding of what you are seeing.
Old 12-03-2011, 06:32 PM   #4
With a voltage detector/ tic tester
Old 12-03-2011, 08:09 PM   #5
Diagram
I hope this helps
Old 12-03-2011, 08:38 PM   #6
Try a multimeter and measure to neutral.
Old 12-03-2011, 08:45 PM   #7
Well, your diagram doesn't depict what you said.
What is the black of the 12-3 connected to at the switch?
jammin06 is offline   Reply With Quote
Old 12-03-2011, 09:31 PM   #8
joed's Avatar
Rewards Points: 11,552
To answer the original question, Are you using a digital meter? If you are then it is likely a phantom voltage.
The diagram is correct to have two switched lights and the receptacle that is not switched.
Old 12-03-2011, 10:11 PM   #9
The black 12-3 at the switch is connected to the power source with a connector
Old 12-05-2011, 07:35 AM   #10
Fixed
Thanks to all for help. It was phantom voltage. Had a loose neutral.
