Bosch Washer With A Leviton 15Amp 250V 2-Pole 3-Wire NEMA 6-15P - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 08:15 AM   #1
bosch washer with a Leviton 15Amp 250V 2-Pole 3-Wire NEMA 6-15P
what changes to the machine can I do to be able to run this machine from a normal Canadian plug outlet. Can I just change the plug to a plug that fits into a Canadian step up transformer and just plug the machine into the step-up transformer and then plug the transformer into a Canadian 110v outlet?
outlandr is offline   Reply With Quote
Old 11-06-2011, 08:33 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,944
What is the current rating on the machine? It probably requires too much power to operate from a 120V circuit, otherwise they wouldn't make it a 240V appliance.
mpoulton is online now   Reply With Quote
Old 11-07-2011, 05:44 PM   #3
Thanks mpoulton, yes im aware that it will more than likely draw too much power, I was wondering if someone had a work around for it, something like a 2x 110v receptical adapter where it uses 2 110v outlets coming from the wall but leads to just 1, ( now a 220volt), outlet to plug the appliance into, of course the outlet would have to be wired to a higher wattage receptor on the house power board, but this solution is not reliable and is susceptible to dangerous outcomes.
But thanks anyways. By the way the washer is supposed to plug directly into the matching dryer which in turn plugs into a 240v dryer outlet, I just don't have the dryer lol.
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Question: Is using 12/2 wire, ok on 15amp breaker/outlets? ehoez Electrical 3 07-14-2008 07:41 AM
