A Boring Question - - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2008, 08:40 PM   #1
Learning by Doing
Leah Frances's Avatar
A boring question -
I, as some of you well know, am rewiring my porch. I ran into this today. The horizontal two by four sits in front of another piece of non-dimensional lumber - total depth of the space = 2 3/4 inches. Together they make a nice solid mass that I need to run some wires through. I need to run 2 12/3s and 2 12/2s to a switch - imagine it for the time being.
Since I am trying to measure twice cut once - or not drill anything without thinking about it first, I ask: Is drilling through it totally a bad idea? Against code? Morally corrupt?
Rant - I've had a *************** of a time figuring out how the genius before me wired the exterior wall of the porch. Found out today - they just ran the wire outside and down to the basement - Is it possible that all the coats of paint ameliorated the fact that it wasn't outdoor rated cable? Lazy -hole.
If I could only remember to THINK about what I was doing before I did it.
Last edited by Leah Frances; 04-01-2008 at 08:41 PM. Reason: To add apology to the forum for using pg-13 language - sorry.
Leah Frances is offline   Reply With Quote
Old 04-01-2008, 10:43 PM   #2
Union Electrician
goose134's Avatar
Leah, drill it.
I've actually had paint that was holding up a small piece of moulding. As it has been said: drywall conceals a multitude of sins. Sometimes, so does paint!
goose134 is offline   Reply With Quote
Old 04-01-2008, 11:28 PM   #3
Idiot Emeritus
Rewards Points: 1,492
If you drill in the center 1/3 of a horizontal beam, it'll have the least effect on its strength.
The effect of a load on a horizontal beam is to pull the bottom apart, and mash the top together. It doesn't really affect the middle much at all. Consider the 'I-beam' type of manufactured joist. Thick on the top and bottom, and thin plywood in the middle.
Rob
micromind is offline   Reply With Quote
Old 04-02-2008, 12:39 AM   #4
If you drill it you won't be recessed the required 1 1/4 inches form the back side. I would notch it and nail plate it. Simple.
220/221 is offline   Reply With Quote
Old 04-02-2008, 09:49 AM   #5
Learning by Doing
In this case, fiberboard covers a multitude of sins. I'm replacing it with drywall inside and hardiplank outside.
I think I'll notch and protect. Thanks for the help. I've got one of my three circuits run. I hope to get the rest of my rough-in done in the next week!
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
geothermal question robert smith HVAC 2 01-17-2008 09:48 PM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
