Borewell Compressor Motor Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 06:53 AM   #1
Borewell compressor motor problem
Dear Mr.Nathan,
Thanks for your reply.
I had a Big problem in my home for the 6 months can you solve it?
thangapandian is offline   Reply With Quote
Old 08-21-2012, 07:47 AM   #2
Licensed electrician
Rewards Points: 1,486
You are going to need to describe the problem before anyone knows how to solve it.
Old 08-22-2012, 04:20 AM   #3
Dear Mr.Jim Port,
Thanks for explanation,further my problem is 7 months before i bought 1.5 H.P Moter for my new construction that time the moter was running with out any problem in some times in very near of Main board. some time means in our area has low voltage covering area.three months before some careless mistake the moter is collepsed and it was repaired by winding guy with the help of our electrician and Borewell compressor moter had been shifted to very near of my home it is apart from 70 feet from existing place the line comes under local tranformer line.but this time My compressor was not worked so that we carried this one to moniter in electrical work shop.After the elctrician confirmation I took out the Compressor moter to my home surprisely it is not work in our home but in other area it works.What Happend to My compressor motor kindly say this Add we do some more works done for running process of it .Can you want clarificatiojn about this pls ask the question me ,I shall tell you what are the steps we done for running process.
Old 08-22-2012, 04:22 AM   #4
Dear Mr.Nathan ,
Could you arrange for alternative person for discuss with me for above my statement.
Old 08-22-2012, 04:59 AM   #5
Rewards Points: 3,256
A local electrician with a meter should be able to solve your motor problem. If you have the correct volts for the motor (including voltage drop through wires), at the correct cycles and number of phases, the motor should run. Also any control devices need to be checked. What happened to the motor that required it to be repaired by a winding guy?
Mr. Nathan is probably the forum owner and it is unlikely that he is seeing your messages.
zappa is offline   Reply With Quote
Old 08-22-2012, 05:20 AM   #6
A local electrician checked the kind the current flow is 200 volt in the starter point of the moter and 190 volt in the main board on before with help of wireman we should strongly bonded neutral line in the poleand this is single phaseline so he pasted the line strongly in the same line.
Old 08-22-2012, 05:28 AM   #7
And we should increase the Capaciters range also.Starting capaciter initially 100-120 TFD it would be increased to 120-150 again we increased 150-200 at the same time we increased running capaciter from 25 TFD from 36 TFD but no more favourable result.If we have running belt from the compressor motor has to be run,we put the belt connect with compressor the compressor would struggiling to start up and the total electrical line down in the previous position.
Old 08-22-2012, 05:33 AM   #8
Dear Mr.Zappa,
Due to My excitement i should not convey my thanks to you for response.sorry for the in convinence and once again I convey my heartiest thanks to your self.
Old 08-22-2012, 05:42 AM   #9
Dear Zappa,
Are you in the line?
Old 08-22-2012, 05:59 AM   #10
I need to go to work now. Not knowing your setup here are some quick ideas and other people here can give help also. It sounds like you have low line voltage.
1) 208 volt motor if yours is a 240 volt motor.
2) Buck boost transformer.
3) Centrifugal clutch on the motor shaft.
Old 08-22-2012, 06:16 AM   #11
I given the details as you required.
1)240 volt motor
2)No more tranformeris there only coil and contenser are there.
3) central petal switch on the motor shaft.
Old 08-22-2012, 08:11 AM   #12
Rewards Points: 1,578
thangapandian, which country are you located in? I'm guessing Thailand?
bob22 is offline   Reply With Quote
Old 08-22-2012, 09:39 AM   #13
These were possible solutions, not questions. Also, if this compressor has a tank, make sure your air unloader valve is working properly.
Old 08-29-2012, 06:19 AM   #14
Dear Zappa,
I am living in india
Old 08-29-2012, 06:22 AM   #15
I am ensure air un loader is working properly
