Bored Hole Spacing For 12/2 In Joists ? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 01:36 PM   #1
bored hole spacing for 12/2 in joists ?
Sticking with the rules of no drilling within nMddle third of span and drilling hole size 1/3rd depth doesn't matter to me since I am only drilling 1/2inch holes in center of depth. Is there any code related to hole or cable spacing withing the joists?
jeeper is offline   Reply With Quote
Old 03-11-2009, 04:06 PM   #2
Registered User
Termite's Avatar
Nope, nothing in the code addresses the proximity of holes. It comes down to the fact that holes that are spaced closely or grouped together essentially cause the joist to perform as though one big hole was drilled in it. The best advice you can get is to leave at least a couple inches of wood (preferably more) between holes.
1/2" holes are pretty small and it would take a lot of them in one general area to compromise a joist.
Old 03-11-2009, 05:25 PM   #3
Usually what I have seen when dealing with TJI or floor joist is take the size of the hole you're drilling and double it from the edge of one hole to the next. So a 1/2" hole would need 1" from the edge of the first hole to the next. I have read many articles from our local building inspectors when wiring houses.
gunner is offline   Reply With Quote
Old 03-11-2009, 05:35 PM   #4
I checked my IRC 2000 and it does not prohibit drilling small holes all the way up the center of a stud.
This many holes would weaken the stud's resistance to buckling in at least one of two horizontal directions, but since nobody does this there is no prohibition in the code.
So, what I get from this is that codes do not address every conceivable situation if they are unlikely to occur.
Old 03-11-2009, 06:12 PM   #5
Ok, Thanks for the replies. I guess it is what I thought that there is no code on that just common sense. Yeah I wasn't going to string them together that close just 3-4 holes spaced at 2 inches. Thanks again for all the replies.
chuck
Old 03-11-2009, 07:38 PM   #6
Stagger them
220/221 is offline   Reply With Quote
Old 03-12-2009, 08:38 AM   #7
Registered User
Termite's Avatar
Very true. Issues of workmanship can still be made an issue if the inspector chooses however.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
