Boosting To 277volts - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 09:33 AM   #1
Lightbulb
Boosting to 277volts
Trying to find out the cheapest and best way to boost power from 220 v to 277 v to do some work on air conditioners in my shop for repair.
KBAT is offline   Reply With Quote
Old 09-13-2011, 09:37 AM   #2
Code05's Avatar
Rewards Points: 1,104
You want to convert from 120/240 1 phase to 480Y/277 3 phase. Not cheap at all.
Code05 is offline   Reply With Quote
Old 09-13-2011, 09:54 AM   #3
Rewards Points: 246
240 may operate the equipment just fine if you are just testing. I know we test 277 volt lighting fixtures with 240 all the time.
J. V. is online now   Reply With Quote
Old 09-13-2011, 10:04 AM   #4
Code05's Avatar
Lighting ain't a motor/compressor.
Old 09-13-2011, 12:04 PM   #5
joed's Avatar
Rewards Points: 13,722
The AC are likely three phase. If you have 240 volts you likely only have single phase. A transformer will boost the voltage to 277 but if you need the three phase that is much more complicated.
Old 09-13-2011, 06:49 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
A transformer is the simplist option.
You will have to find one with enough current capacity,
And do you need only single phase ?
good transformers are not cheap !
but if you look around a bit you could find one !
dmxtothemax is offline   Reply With Quote
Old 09-15-2011, 05:57 PM   #7
Electrical Contractor
kbsparky's Avatar
How big of a unit?
I might suggest a buck/boost 240 - 16/32 transformer be used .... You can get close to 277 on the output (272).
-KB
Boosting Air Flow to Second Floor franleck HVAC 8 06-02-2009 09:04 AM
Boosting home water pressure Bpreuett Plumbing 4 11-06-2007 02:06 PM
Hot water boosting shower pump Sosh Plumbing 3 04-17-2005 09:52 PM
