Bonding Well Casing - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Jim Port
Old 11-01-2016, 10:31 PM   #1
Rewards Points: 280
Bonding well casing
Even though I passed rough inspection, the inspector told me I needed to bond/ground the well casing (will check at final inspection). He said I could drill a hole in it and put a ground bar or something?
I'd like to know what I should buy (platt, HD or L's) and some pictures would be great.
Thanks!
Richard Pryor is online now   Reply With Quote
Old 11-01-2016, 10:34 PM   #2
Rewards Points: 280
Re: Bonding well casing
My casing is made of steel I believe.
Old 11-02-2016, 12:00 AM   #3
Licensed electrician
Rewards Points: 1,754
The only steel well casing I grounded, I drilled and tapped a hole for a 1/4-20 bolt and attached a lug directly to the casing.
Knows a Little likes this.
Bonding Natural Gas Corrugated Stainless Steel Tubing (CSST) agd202 Electrical 12 05-06-2015 11:08 AM
Question regarding bonding screw. dabeast Electrical 14 10-09-2013 09:26 AM
Bonding Electrical Panel folkda Electrical 3 11-02-2012 11:37 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
How to transition from door casing to baseboard? RxScram Carpentry 12 11-13-2009 11:10 PM
