Bonding Water/gas Pipe : Smoke Alarm ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 01:24 PM   #1
Rewards Points: 101
bonding water/gas pipe : smoke alarm ?
A few loose ends to tie up before my inspection: I know I have to run a bonding wire across the gas meter the same size as my grounding wire but how does that tie into the panel? Does the ground wire on the furnace take care of that? If so why does the bonding wire have to be 4ga when the furnace is 12ga? On my water lines in I'm changing to PEX at the first coupler/connection where the galv pipe comes into the house, do I need to run a ground wire out to that pipe? From where? And lastly I ran 12-2 to my first smoke alarm and then 12-3 between the alarms... I haven't bought the alarms/detectors yet but I took a look at them at the store and they only have 3 wires without anywhere to hook the ground, can you help me out here? Thanks once again, 1
1dumbquestion is offline   Reply With Quote
Old 01-09-2012, 01:32 PM   #2
Julius793's Avatar
Anything that your grounding should end up in the panel. Now as far as your water pipe coming in you must connect if any metal enters, if the pex starts a little after the meter you must use a jumper. I can't tell you about gas meter or furnace because I don't know what your talking about. And your smokes just connect the grounds in the box and leave them they don't get connected to the smoke.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-09-2012, 01:55 PM   #3
Rewards Points: 101
Ok, I'm one step closer now knowing what to do with the smokes, so on the stub of pipe that enters under the house I can just run a wire on a clamp from there staight to the ground bus on the panel? does it need to be 4ga? On the furnace/gas pipe I'm not sure what I'm talking about so I'm not at all surprised if I didn't make sense. Thanks, 1
Old 01-09-2012, 01:58 PM   #4
Julius793's Avatar
Correct proper clamp on one side and the grounding bus on the other.
Old 01-09-2012, 02:41 PM   #5
Rewards Points: 101
4ga? or can I use something smaller? 200A panel.
Old 01-09-2012, 02:42 PM   #6
Julius793's Avatar
4guage
Old 01-09-2012, 03:42 PM   #7
Rewards Points: 101
4guage
any negotiation on this one? I'd like to use say... 18ga but will be willing to go as high as maybe 12ga?
Old 01-09-2012, 07:30 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Lol...no, not negotiable. And no, you can't string a bunch of 18's or 12's together to make a #4 equivalent .
Kyle
The Following 2 Users Say Thank You to SD515 For This Useful Post:
ben's plumbing (01-09-2012), Speedy Petey (01-09-2012)
Old 01-09-2012, 08:27 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
The gas pipe does not need additional bonding provided the furnace has a proper grounded circuit feeding it.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 09:58 PM
Smoke alarm preference James Con Electrical 14 03-28-2008 09:31 AM
smoke alarm - ground wire Potomac101 Electrical 7 02-06-2008 07:25 AM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 02:41 PM
