Old 09-14-2006, 08:37 PM   #1
Which bonding method proper???
I live in Ontario. I'm wiring a cct of outlets and can't seem to decide which is the proper method. A "CEC simplified" book states that a pigtail is required from the receptacle to the incoming and outgoing ground.
My single gang boxes have two bonding screws.
Is the following within code:
1. First ground terminated at one bond screw.
2. Second ground wrapped around second bond screw and terminated at ground lug of receptacle.
10-808(2) of CEC does not mention pigtails, but does state that "the arrangement shall be such that the disconnection or removal of a receptacle, fixture, or other device fed from the box will not interfere with, or interrupt, the bonding continuity."
It would seem the above method will allow removal of receptacle without disrupting the bonding continuity.
I do know that only one ground conductor per bond screw. If not, then I can't understand the purpose of the second bond screw in a single gang box.
Help!
Nestor is offline   Reply With Quote
Old 09-15-2006, 01:54 AM   #2
Electrician
I do this way all the time and no inspector has turned it down. You could also put one under the ground screw and then marrete them and make a pigtail to go to the ground on your plug. I don't like this because you are adding another marrete and it makes your box look more messy.
Darren
darren is offline   Reply With Quote
Old 09-15-2006, 07:18 AM   #3
Thanks for your reply!
That was my thoughts too. It didn't seem to make sense to add another marrette.
Proper Attic Insulation reikiray Roofing 5 08-04-2007 11:59 AM
what is the proper way to plaster ? kenny357 Building & Construction 1 06-06-2007 07:20 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 09:16 AM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing 1 01-07-2005 02:38 PM
