Bonding And Grounding Of Pool Pump/motor - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 11:22 AM   #1
bonding and grounding of pool pump/motor
i have a 12x24x52 intex ulta frame pool. the only part of this pool that is metal are the top beams and the u supports. would this type of pool have to be bonded? there is also a deck on one end of the pool, but it's not connected in any way. there is a bonding lug on the motor, so do i just run an 8awg wire from that lug to the nearest u support? the next part is a grounding . if i run a line from the panel to a GFCI outlet, will that suffice for a ground? the cord is already grounded in the motor. i'm not the best at electrical, but i do have some practical expierence. thanks any help would be appreciated. gpike19
gpike19 is offline   Reply With Quote
Old 07-22-2011, 12:56 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Pools are very involved. Read article 680 of the NEC. You should consult a licensed electrical contractor. Search this forum for pool threads. There is plenty of information here and after reading it you will realize you need to hire a licensed electrical contractor.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-22-2011, 01:18 PM   #3
Rewards Points: 58
You need to call an electrician. This pool must be bonded, the water must be bonded, the deck must be bonded (yes, wood decks too) there must be an equipotenial bonding grid installed and a convenience GFCI receptacle installed.
Make sure the electrician pulls a permit so you don't get killed or kill someone else.
The Following 2 Users Say Thank You to J. V. For This Useful Post:
electures (07-22-2011), NJMarine (07-23-2011)
Grounding a swimming pool bonding grid Simbilis Electrical 8 05-25-2011 12:46 PM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 07:08 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
