Bonding & Ground Rod Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2008, 11:34 AM   #1
Ok...almost got this thing together. Let me preface by saying that we have no inspections or anything in our area....I want to do this properly, though I get a lot of "we could rig it this way" even from our local co-op guys...go figure LOL
Anyway, I have a meter on pole w 200a disconnect that has bonded neutral/ground with 4 wire (4/0-4/0-2/0-2 Alum) running to my workshop(that stuff is per poco). In the workshop is a main panel with a 200a breaker.
My questions:
1. Do I leave the ground & neutral seperate in the workshop panel or bond them ??
2. Is a buried ground rod also required at the building ?? or is the poco earth ground on the pole enough ?
Thanks all for your help.
Brad
bradsguns is offline   Reply With Quote
Old 06-13-2008, 11:41 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
#1 Seperate them. Install a ground bar made for your panel
#2 Install a ground rod and connect to the ground bar in the panel. If the panel came with a green bonding screw, throw it away.
jbfan is online now   Reply With Quote
Old 06-13-2008, 12:31 PM   #3
I just want to verify then...If I separate ground & neutral at the shop...do I hook the 4th wire (ground) coming from the meter to the grounding bar in the box, along with the wire to the ground rod ?? Or does that 4th wire get hooked somewhere else ??
Thanks,
Brad
Old 06-13-2008, 12:55 PM   #4
jbfan's Avatar
Rewards Points: 650
They both get hooked to the grounding bar.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 10:17 AM
Ground Clamps Question integlikewhoa Electrical 40 02-28-2008 09:13 PM
Bonding Ground and Neutral matrix733 Electrical 11 11-28-2007 06:22 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
