My first post.
If you look at he attached picture. The home inspector saw that my panel needed bonding screws.
This is a SquareD panel installed in 1979.
I fixed the double tapped Neutrals.
This panel has an exact sister to it right next to this one.
I think this is the First and Main panel Because a Home Inspector only indicated this box was missing bonding screws.
- With that said.
Look at the Neutral Bar - All three bars are connected with a thick steel plate so no neutral or ground could be isolated....
Either way I have been looking up bonding and haven't got a real understanding. On placed looked like you only bond the main box. But the schematic showed the Neutral bonding bar in a sub-panel as isolated see the attached URL
http://www.diychatroom.com/attachme...ounding-question-4-wire-subpanel-detached.jpg
To take a stab at it...
The bonding screw makes contact with the Panel Box Thus grounding it...
---Tangent question I don't understand what the big deal is... Ground/Neutral is Ground/Neutral no matter if you are in a Main or sub box... (Okay lay into me)..
First Question - Do I really need the bonding screw in my panel.
Sub Question - Can you point me to the reasoning to bond or not to bond?
- With that said.
