Bonding Above Ground Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 01:17 PM   #1
Unhappy
Hello, we recently purchased an above ground pool and had it installed. The city building inspector came out to inspect the electrical and said we would need a bonding grid around the pool and bonding plate in the trench. When I questioned how to do this, his response was to contact the pool manufacturer. I have done this and the manufacturer tells me that since my pool is aluminum wall and the rest of it is resin, I do not need the grid and plate, but will need to insert a bonding screw to the skimmer and drop a copper wire from the screw into the ground. I asked for a schematic on how to do this, but they could not help. I am also concerned that they told me something different then the building inspector did. Can anyone help me with this please? Right now I regret getting this pool, hoping someone can walk me off the ledge. Thank you so much for you time.
mboyer is offline   Reply With Quote
Old 04-30-2012, 01:36 PM   #2
Licensed electrician
Rewards Points: 1,266
If the pool has metallic parts like the walls, pumps, and pool water etc they need to be bonded with a solid #8 copper conductor.
The bonding outside the pool for the walking surface varies based on which code cycle is currently being enforced in your area.
The NEC covers pools in Article 680.
Ground connection / Bonding in EMT jamiedolan Electrical 30 02-16-2013 02:20 PM
Exposed pool ground wire, can I just cut it? Drywallhelp Electrical 14 08-28-2011 05:25 PM
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 06:21 PM
Grounding an above ground pool wcolon Electrical 18 09-02-2009 03:25 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
