Old 05-25-2012, 02:26 PM   #1
bonded pool filter
older pool sysstem put in by licensed electrician---lug on back of pool filter snapped off that normally copper wire attached so i am now unable to attach. Can i attach to another part of the motor, ie the frame or does this need to have a new lug fixed to motor?
twobrien is offline   Reply With Quote
Old 05-25-2012, 02:43 PM   #2
Licensed electrician
bonded pool filter
If the lug bolts on you should be able to replace it.
Should my retaining wall with rebar be bonded to pool grid? AlwayzSomethin Electrical 13 05-26-2012 06:06 PM
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 12:21 PM
Is being shocked in a properly bonded pool truly impossible or just improbable? LeighB Electrical 28 09-01-2011 09:35 PM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 06:49 PM
Tips on how I can get this electrical job done for a hot tub in backyard. the punisher Electrical 34 08-24-2010 07:08 PM
