Bonded Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 04:53 PM   #1
Rewards Points: 528
bonded panel
]I got the panel bonded with screw(1 1/2 "green one did not work-too short) and also used a jumper to neutral bar for double bond..
Does it matter that the green one is not used?
Also grounded aluminum to copper pipe
with anti corrosion on the aluminum(not on the copper pipe).bonded panel-imag0157.jpg
hidden1 is offline   Reply With Quote
Old 11-20-2012, 08:29 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Is the ground clamp listed for AL conductors? IS the mounting screw for the lug a machine screw?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-20-2012, 11:41 PM   #3
Rewards Points: 528
When looking at them they all said either for copper only .. or... for Al only (didnt have "FOR BOTH" )and i have a big copper pipe..didnt see one for both in a main electric supply store-only online.
I have applied the NOALOX to the aluminum.Before contact w copper.
Id rather it be inserted at the smaller area with the smaller clamp-on it seperate- than have to use a larger amount of it on the AL clamp when its in contact with the large copper pipe.
Old 11-21-2012, 02:51 AM   #4
Electrical Contractor
kbsparky's Avatar
That pipe clamp is for use with armored copper ground wire.
You should get a clamp made of zinc die-cast metal which could be used for either copper or aluminum wire. Here is one from Arlington, cat #720Z:
-KB
Old 11-21-2012, 08:51 AM   #5
electures's Avatar
The clamp is listed for use for a GEC with or without armor. I question whether it is listed for AL. The packaging should indicate if it approved for use with AL.
Old 11-21-2012, 08:59 AM   #6
electures's Avatar
No-Ox is not needed. The small saddle clamp is used for bonding the metallic armor of the GEC if present which in your case is not. I'm still questioning the screw you used to mount the lug to the panel. It it a self tapper?
This picture kind of shows how the saddle clamp works;
Old 11-21-2012, 10:21 AM   #7
jbfan's Avatar
Rewards Points: 490
Looks like a self tapper.
Old 11-21-2012, 11:03 AM   #8
Rewards Points: 528
The Following User Says Thank You to hidden1 For This Useful Post:
jbfan (11-21-2012)
Old 11-21-2012, 11:16 AM   #9
Rewards Points: 528
so the zinc clamp will do fine with copper? that one i had was brass
Old 11-21-2012, 11:33 AM   #10
electures's Avatar
Yes. And the screw is fine.
Old 11-21-2012, 01:49 PM   #11
Rewards Points: 528
Ok thanks...Here is what the zinc one i have says on it
Old 11-21-2012, 04:22 PM   #12
electures's Avatar
Attachment 60859
Attachment 60860
This clamp appears to only be listed for copper conductors. It is not listed for AL conductors. What is on the packaging for the clamp in the earlier photo?
Old 11-21-2012, 06:29 PM   #13
Rewards Points: 528
Brass for copper connections..(no AL)
Odd that a local electricians supplier wouldnt have it if it were NEC required..
So many older homes still use/need these..
Old 11-22-2012, 06:14 AM   #14
electures's Avatar
It has nothing to do with material the clamp is made of. It depends on what the clamp is listed for. Somewhere on the clamp it should indicate what it is listed for. Such as AL only, or CU only or AL CU. check the clamp for what it is listed for. Happy Thanksgiving!!
Old 11-22-2012, 12:18 PM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
In argeement with Electures ... that clamp is not for aluminum wire . Try Burndy pipe grounding clamps they have always been my choice.
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
