Boiler Always Making Sound As If Water Is Running Through It - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 10:34 AM   #1
Boiler always making sound as if water is running through it
Hi All, does anyone know why a boiler that is less than 4 years would always make a sound of flowing water as long as the switch button is on, even when the timer on the boiler and the central heating thermostat are off. It is a Baxi Solo HE, both for hot water and central heating, please?
FrancisYinka is offline   Reply With Quote
Old 07-23-2012, 10:43 AM   #2
joed's Avatar
Rewards Points: 13,766
Water sound is usually the result of air in the lines. Since your boiler is used for hot water is is always operating to heat the water, even in summer.
Old 07-23-2012, 12:27 PM   #3
Rewards Points: 1,548
Do any of the radiators feel warm?
You need to verify that the circulator pump for the radiators is not running in summer.
Old 07-23-2012, 05:07 PM   #4
Thanks guys! @joed, what's the implication of that, does that mean I can turn the switch button off in summer as I wonder this might be the reason for a high gas bill? @AllanJ, no the radiator doesn't feel warm as the thermostat is off, however the pipes leading to the boiler itself are sure hot. It's just that the sound is increasingly loud these days.
Old 07-23-2012, 07:01 PM   #5
It is not unusual for a small amount of boiler water to drift up to the radiators (gravity flow) in summer and most folks don't worry about that. You can install a ball and lever valve in either the pipe exiting the boiler to the radiators or the pipe returning from the furnace back to the boiler if you really want to. You will have to remember to re-open that when the heating season begins. If you do have or install such a valve it would also be a good idea to install a cutoff switch for the circulator so the thermostat can't turn the heat on with the valve closed.
Old 07-23-2012, 09:38 PM   #6
joed's Avatar
If you turn the switch off you will no thave any hot water.
Old 07-24-2012, 07:22 AM   #7
Rewards Points: 1,300
Why is the boiler hot if there is no demand?
danpik is offline   Reply With Quote
I hear water running in my pipes 24 hours. Prata Plumbing 22 03-14-2012 07:08 AM
modcon boiler and primary/secondary piping silky HVAC 45 11-21-2011 04:02 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
