Blue Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 08:37 PM   #16
Do you live in Chicago? They require conduit...means you might have a ground.
Sounds like 120/208 if you have a neutral in there.
A house with 3 phases?
rgsgww is offline   Reply With Quote
Old 01-17-2009, 10:24 PM   #17
" Euro " electrician
frenchelectrican's Avatar
The only time I heard the bleu wire in USA typically used for 3 phase system or you are in the conduit { pipe } area then they run indiviual conductors.
In European area the bleu is used for netrual conductor.
If you have Red , Black , Bleu and White and Green { if there } becarefull this what most electricians call them full boat system that colour code typically tell that is 208Y120 system.
Are you in the Condo or just a reguar home ?
For the ceiling fan most case you will useally find a switch for the luminaire/ fan set up.
Old 01-18-2009, 02:33 AM   #18
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by xamplesample View Post
Is the blue wire the neutral wire?
Only in ISO (Int Stds Org)
This is important to know because I have worked with ISO power cords where the wires were coded Brown, Blue, and Green.
The way the World is going with ISO we may be in the minority with our Black & White.
WikiAnswers - What is the International colour code of AC wiring
& Stay Safe
.....Bob Lavery
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
