Blue Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 07:26 PM   #1
Question Asker
Send a message via AIM to xamplesample
Blue Wire
I took down an old ceiling fan in the living room.
There are two wires, Black, and Blue.
Does this mean that if i put a ceiling light up, it will always be on?
Is the blue wire the neutral wire?
xamplesample is offline   Reply With Quote
Old 01-17-2009, 07:27 PM   #2
Question Asker
there is no switch for these wires by the way...
Old 01-17-2009, 07:56 PM   #3
I assume your not in the usa or canada?
This site is mostly usa and canada...there are some experts that know about other countries.
I hope marc gets here.
rgsgww is offline   Reply With Quote
Old 01-17-2009, 08:06 PM   #4
Question Asker
Usa
im in Illinois
Old 01-17-2009, 08:08 PM   #5
In the UK the usual voltage is 220v. I'm unsure if one wire is grounded. Maybe not! If the removed fan had a switch on it somewhere, odds are that the 220 volts is present on the wires and if you connect a lamp to these, it will remain lighted! In this case, the new lamp fixture will have to have a switch of some sort installed on it! Addendum: Wikepedia states that one conductor is a neutral, but did not say if it was earthed (grounded).
Old 01-17-2009, 08:09 PM   #6
Originally Posted by xamplesample View Post
im in Illinois
Blue wire? Kind of odd.
You need a multi meter to check for hot and neutral. I am not sure which wire is neutral as it is not a normal color.
How was the fan grounded, or was it?
Old 01-17-2009, 08:10 PM   #7
Question Asker
fan?
the blue wire is a Line 3 Phase.
the other wire is the hot wire.
does this mean i should only put up another fan?
Old 01-17-2009, 08:11 PM   #8
Question Asker
no ground
there was no ground wire...it's an older house
Old 01-17-2009, 08:13 PM   #9
Rewards Points: 876
In European cord sets, the blue is neutral, brown is hot, and green with yellow stripe is EGC (ground).
Where are the blue and black wires, on the fan, or in the house wiring?
Ultrarunner2017 is offline   Reply With Quote
Old 01-17-2009, 08:15 PM   #10
Rewards Points: 876
Line 3 phase? What country do you reside in?
Old 01-17-2009, 08:16 PM   #11
Question Asker
Omg
i Am In Illinois,usa
Im In In The Usa Usa Usa Usa Usa Usa Usa Usa
Old 01-17-2009, 08:20 PM   #12
Rewards Points: 876
Oh, I'm very sorry. I saw the post that you are in Illinois, but I didn't realize that it was you, the OP who posted that.
I am having a problem here. Dual monitors, sometimes get screwed up. I've switched off the 2nd monitor, so I think I will be ok now.
So, the blue wire you are referring to is from the fan?
What color is the wire it was connected to in the outlet box?
I would think white, neutral, but then I don't want to assume anything.
BTW, I am in New Jersey... U.S.A!!
Old 01-17-2009, 08:21 PM   #13
When did you get back?
Old 01-17-2009, 08:25 PM   #14
Question Asker
My greatest apologies to everyone.
I just took my lil' led flashlight and took another look up into the small hole that the blue and black wire come out of. Low and Behold, there is a third wire stuck up in the whole, i can tell because it's capped like the others. I assume it's the neutral white wire.
Old 01-17-2009, 08:29 PM   #15
Electrician
ctsmiths's Avatar
Rewards Points: 150
Its like you said, 120/208 three phase is identified with black, red, blue. Have you tested to see if the blue is hot? someone probably used a 4 wire cable instead of a three wire.
ctsmiths is offline   Reply With Quote
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
