Blue Plastic - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 02:32 PM   #1
blue plastic
is it ok to use the blue plastic work boxes for my outlets in a garage were the studs are exposed?
Mule98 is offline   Reply With Quote
Old 09-17-2012, 02:36 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes, they can be used.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-17-2012, 02:40 PM   #3
Licensed electrician
Rewards Points: 1,038
Are you using plastic sheathed cable? If so the answer is yes. If you are using something like MC cable the answer is no.
Old 09-17-2012, 02:49 PM   #4
just using romex
Old 09-17-2012, 03:02 PM   #5
electures's Avatar
Attached or dettached garage? What version code is in affect where you are from?
Old 09-17-2012, 03:07 PM   #6
detached and i do not know what version- i'm in south east indiana
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 11:16 AM
Can you snake plastic pipes? rosemonster Plumbing 10 01-17-2011 08:09 AM
What size plastic sheeting to use? Joe D Painting 2 01-11-2011 12:03 PM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
