Blue Color Inside Of Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2009, 11:33 PM   #1
blue color inside of wall switch
So we changed all of our wall switches to update to a white color. My wife noticed tonight that if she turned on/off a light quickly enough she could see a blue colored sparkish thing inside the small area around the switch. When I changed all the switches I just reattached them directly the same way they were previously connected. I did the same for the outlets and they all test out fine with that little plug in device.
What is going on and should I be concerned?
Thanks.
TableTiger1 is offline   Reply With Quote
Old 08-05-2009, 03:41 AM   #2
Rewards Points: 2,350
Perfectly normal.
Old 08-05-2009, 05:33 PM   #3
Electrical Contractor
kbsparky's Avatar
Try unplugging a toaster or vacuum cleaner while it is running.
You will see similar sparks in the receptacle when you do so.
What you are witnessing is the electrical arc that is created when disconnecting power under load.
-KB
Old 08-05-2009, 08:32 PM   #4
Bigplanz's Avatar
Rewards Points: 990
The reason they tell you not to flip a light switch if you smell gas is because of the spark your wife saw when you flipped the switch. The ever so brief flash will make a big kaboom if gas is present.
Bigplanz is offline   Reply With Quote
Old 08-05-2009, 09:19 PM   #5
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
The kaboom will only happen if the gas concentration is between the lower explosive and upper explosive limits.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 08-05-2009, 09:53 PM   #6
Understanding purpose of AFCI breakers!
In this case the sparking (arcing, really) was the result of a normal action. But when there's continuous arcing across two points due to a break in a wire or terminal, it could ignite a fire even without the presence of gas. The early AFCIs did not react to an arc fault on a Neutral conductor. Thankfully, we have Combination AFCIs today.
p.s.: The above Mini-lecture was not meant for BigPlanz, who knows all of this stuff better than I do. But was a recounting of personal experience.
(Now more than ever) Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
having trouble with a wall timer that will not switch kenny357 Electrical 4 08-06-2008 02:49 PM
wall switch repair Code3 Electrical 2 12-27-2007 03:39 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
