Are Blue Boxes Required For Garage Flourescent Light Fixtures? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 03:27 PM   #1
Rewards Points: 150
Are blue boxes required for garage flourescent light fixtures?
Or, can I use one of the black plastic inserts and run the 14/2 directly into the metal housing? These are going in the ceiling area which will eventually be sheetrocked over.
sheslostcontrol is offline   Reply With Quote
Old 03-06-2011, 04:39 PM   #2
Licensed electrician
Rewards Points: 1,616
You need to use a cable clamp to secure the cable to the fixture housing.
If boxes are used above the fixture you need to provide a hole the size of the entire face of the box in the fixture to allow access to the splices.
Old 03-06-2011, 04:45 PM   #3
iminaquagmire's Avatar
Rewards Points: 338
You can use any listed line voltage box as long as it remains accessible. I believe you're referring to the Arlington black button cable clamps. If so, those are fine.
iminaquagmire is offline   Reply With Quote
Old 03-06-2011, 04:59 PM   #4
Rewards Points: 150
I did one of the fixtures just now -- copied what the original builder of the garage did (last year, which passed electrical rough & final).
He had a box above the fixture with the black/white/ground wires running through a small hole in the fixture (not the punchout). Hope it shows up in the pic.
I would have preferrred just running the romex right into the fixture.. if that's better I'll take down the boxes and do that with the remaining 7.
Old 03-06-2011, 05:16 PM   #5
Rewards Points: 338
That's wrong. The box should not be there like that and the ground looped around the other one is not a proper connection. Loose the box, take out one of the knockouts on the light and put a cable clamp in. Run the romex cables through the clamp and then make your connections inside the light fixture.
Old 03-06-2011, 05:20 PM   #6
That method is not code compliant. I would bring the cables into each fixture and not use a box.
Check this for a better understanding.
http://www.mikeholt.com/reprint_request2000.php?id=3199
Old 03-06-2011, 05:23 PM   #7
Rewards Points: 150
How did my builder get away with this? This is exactly how he wired the 4 existing fluorescent fixtures. Took apart one of his installs to confirm.
I have to put part of the insulator inside the fixture if the clamps are used. So I just wasted 50' in romex by copying what passed a previous inspection. Already stripped the romex on the fixtures I prepped. Luckily I only did 3. The 5 others haven't been stripped yet. I could strangle the builder.
Old 03-06-2011, 05:48 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It's possible the inspector did not actually look at that part of the installation. It is not realistic to think they look at everything. It would be nearly impossible to do so.
Old 03-06-2011, 06:38 PM   #9
Rewards Points: 150
This a little better?
Old 03-06-2011, 06:42 PM   #10
Much better.
Are the fixtures grounded?
Old 03-06-2011, 06:46 PM   #11
Rewards Points: 150
Yes there is a green screw on the metal housing. I ran a piece of 14 gauge copper wire (same as the 14/2 romex) from that to the wires in the clamp.
Old 03-06-2011, 06:47 PM   #12
Rewards Points: 150
Do they normally want the covers left off like this, or buttoned down?
Is outlet box required for vanity light install? jmccask Electrical 4 12-05-2010 07:35 PM
Flourescent light using GFCI outlet Willing2learn Electrical 5 09-12-2010 07:27 PM
Boxes required Steelhead Electrical 4 01-25-2009 05:18 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
Is a Permit required for additional light ? Handy Dave Electrical 7 09-26-2008 11:21 PM
